Just picked up this Tilly and manifold at a swap meet and notice that the bolts holding the carby on have nuts. My Zenith doesn’t. Did all Tillotson carbs have nuts on the bolts or was this one done out of necessity? How many of you have gone down this path with either type of carb? I ask because one of the threads in my Zenith is weak and I’m going to have to do something about it soon.
(Sorry, the Zenith photo is sideways and I can’t fix it.) Additional edit, 9th April ‘18: My Tillotson is actually a Marvel Schebler. Thanks for the correction, Duke36. Last edited by Hoogah; 04-09-2018 at 12:06 AM. Reason: Factual correction! |
Probably out of necessity. The bolt holes probably stripped and this is cheaper than heli-coils.
http://www.model-a-ford-4bangers.com/ |
...if the threads are stripped I prefer to use nuts and bolts as helicoiling removes a substantial amount of the remaining metal
The Tillotson and Marvels are made of pot metal and the threads strip if one overtightens them. I use helicoils but the nut and bolt method works just as well. I have never had a zenith that had lost it's threads. Jack
That looks like a Marvel carb. in photo 1; ditto other posts.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
You can 'weld' up the holes using those aluminum type filler rods, using just a propane torch and then drill and re-thread the holes.
I take it that the intake is for a RHD car?
I agree with those above who said that the thread were stripped so a nut was used. I have the odd one like that and have done LOTS of miles on them. No one has ever noticed but mine is not a car that will ever be judged and I know yours is the same.
If it works, leave it alone and drive on, I say.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
