02-28-2018, 06:26 PM | #1 |
30-31 radiator shell lacing rivets
Does anyone have a picture of an original 30-31 shell lacing showing the rivets from the inside? Are they flat or a slight curve to them?
Brian SATX |
02-28-2018, 06:33 PM | #2 |
Re: 30-31 radiator shell lacing rivets
the back of the rivets always had a slight curve to them.
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
03-01-2018, 06:38 AM | #3 |
Model T guy's have a tool that comes pretty close to the correct shape.
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts https://www.fordbarn.com/forum/group.php?groupid=5 |
03-02-2018, 01:33 PM | #4 |
MSMARON is correct
Changed mine out (original mostly gone) Sorry...no pics
03-02-2018, 02:04 PM | #5 |
This might help you also...
03-02-2018, 04:45 PM | #6 |
https://www.macsautoparts.com/ford_m...-set-tool.html I will sell you mine (used once) for $25 including shipping. These are clunky, Chinese made, but after a couple tries and learning the technique of putting them in and spreading them a tiny bit apart first I got real nice results with the curves for the cowl. PM me if interested
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930. |
03-02-2018, 09:55 PM | #7 |
Thanks to all. ModelACoupe3 sent me pics of his original.
Thanks for the offer on the tool, if only it had come a few days earlier.
Brian SATX |
03-03-2018, 03:32 PM | #8 |
I thought about buying the tool from the vendors but thought it was to pricey for what it is.Instead, I made a tool from a pair of Harbor Fright vise grip pliers and used a Dremel cutoff wheel, a couple of files and about 15 minutes of time. Work's like a champ!
I also used it on the Cowl lacing clips on the ends. Regards Bill |
03-04-2018, 08:49 AM | #9 |
Thank you for excellent photos posting! I will have at making mine today.
They know enough who know to learn. |
03-04-2018, 10:34 AM | #10 |
Marco made a nice rivet setting tool out of a pliers, and he posted pictures of it here some years ago. Maybe a search will find those pictures. I'll try, but I don't always luck out in my searches.
03-04-2018, 03:01 PM | #11 |
The nice thing about the vise grips is you can set the depth of the tool to go only to the bottom of the "V" and you can adjust the tension of the grip. Basically you give it some force to the point of bending the rivet ttangs and the spring in the vise grips does the rest.
The slight radius on the bottom sides of the "^" point of the tool creates the final position of the rivet tangs and starts the bend. To little and it's hard to get the bend started, to much will cause the rivet tangs standing up to tall. It takes a rivet or two to get it working perfectly. Just follow up on the first couple rivets after you have it dialed in. It sounds more complicated than it really is. The only thing I would change is possibly adding some felt on the other side of the tool protecting the finish on the rivet head. I used a rag so it would save the extra step in doing so. Regards Bill |
03-04-2018, 11:53 PM | #12 |
How about filing the top teeth off and making it smooth or after making it smooth, use the dremel to create a little concave area for the head?
03-05-2018, 06:00 AM | #13 |
Thanks Tom -
03-05-2018, 06:07 AM | #14 | |
03-16-2018, 03:14 PM | #15 |
Your welcome.
One of the easiest tools to make and everyone has an old and tired pair of vise grips to spare. Regards Bill Sent from my SM-G920T using Tapatalk |
