Old 01-29-2018, 09:13 AM   #1
Dave1931Pickup
Default Front Engine Mount Springs
I know that the subject of the front engine mount springs has been discussed in many posts. I have given up on getting springs from any of the vendors since it appears that none of them have the correct ones. I have been searching the web and have found a spring that is almost correct to the original ford drawing. It has an I.D. of .507 with a compressed length of .83 instead of .88 and a load rating of 60 lbs. I don't know what Henry did for finish but this one is zinc plated The only major difference is the free length is only 1.5 instead of 1.62. What are every ones thoughts on it being a little short in the non compressed length.
Another drawback is that I have to buy $40.00 worth of a $3.18 spring to meet a minimum for shipping. Anyone want to buy two springs from me?
Dave1931Pickup is offline   Reply With Quote
Old 01-29-2018, 10:20 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Front Engine Mount Springs
Most of my parts come from A&L, Bert's, Bratton's, and Snyder's, so I don't recall which one I bought the springs from, but they worked perfectly. Tighten the bottom spring just enough to pull the front down so the cranking handle slips into place. Remember the rear mount bolts are loose until the front is correct.
Old 01-29-2018, 11:43 AM   #3
700rpm
700rpm's Avatar
Dave, I am curious why you didn’t go directly to one of the suppliers that Tom mentioned, rather than searching the web at random?
Ray Horton, Portland, OR
Old 01-29-2018, 12:08 PM   #4
Dave1931Pickup
I have purchased front engine mount springs from Snyders, Brattons and Sacramento Vintage Ford. All three suppliers sold springs that would not compress beyond 1" which makes the engine sit to high not allowing the crank to line up correctly with the crank nut.
Old 01-29-2018, 12:26 PM   #5
Tom Wesenberg
Might have to try Bert's for original springs then. Bert's 1-800-321-1931
Old 01-29-2018, 12:28 PM   #6
redmodelt
redmodelt's Avatar
Shorten the spring or maybe look for alignment issues else were. Are the rear engine mounts sagging? Is the front cross member bent? If you are using the brass guide bushing, is it sitting down in the hole flat? Has someone in the past removed material from the bottom of the crank guide to get things to line up?
Old 01-29-2018, 12:35 PM   #7
Tom Wesenberg
Does it have a plate welded in as a patch?
Old 01-29-2018, 12:43 PM   #8
SeaSlugs
SeaSlugs's Avatar
My kit from snyders worked perfectly. Just tightened the nut on the bottom to slip the cotter pin in...crank lines up dead center.
If your frame is sagging you will have alignment issues or if anything is bent or welded funky.
Show us a pic of your front crossmember. Also could have an old badly formed repo front mount as well.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-29-2018, 02:03 PM   #9
700rpm
700rpm's Avatar
The spring kits come with three springs, two long ones that go on either side at the top, and one short one that goes in the middle on the bottom. Might you have tried to use one of the upper springs on the lower part of the yoke?
Old 01-29-2018, 02:17 PM   #10
Fullraceflathead
Fullraceflathead's Avatar
I ordered mine from Snyder's last year and it fit perfect.
The Hand Crank fits perfect into the Hand Crank Hole and Crankshaft Nut.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 01-29-2018, 07:18 PM   #11
redmodelt
redmodelt's Avatar
The three springs in the kit; the two long ones are 1 5/8" and the short one is 7/8" free length. If you compress the long one all the way it is about 1 to 1 1/8". If you are trying to compress the long springs down to 1 inch, you have other issues that need to be looked into as I suggested above.
Do you have float-a-motors installed? Bent frame?
Old 01-29-2018, 07:34 PM   #12
CWPASADENA
CWPASADENA's Avatar
I had the wrong springs when I restored my Tudor.
I got a hold of Bert's and they had the correct springs. They worked great.
Bert's also had the correct spring for the cam plunger on the front of the engine.
My experience,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 01-29-2018, 08:18 PM   #13
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
Yes, I'm in for a set.
MickeyT is offline   Reply With Quote
Old 01-29-2018, 09:29 PM   #14
SteveB31
SteveB31's Avatar
Like many repro parts, their are currently 5 companies making different front engine mounting springs. Just because you got the wrong ones, doesn’t mean all of them are wrong. The ones we sell are made by A&L, and black in color, and are made to the Ford blueprint.
Steve @ Bert’s
SteveB31 is offline   Reply With Quote
Old 01-29-2018, 10:42 PM   #15
Dave1931Pickup
Steve @ Bert’s
Thanks Steve. Too late to call and order today. I will call tomorrow.
Dave
Old 01-29-2018, 10:59 PM   #16
Purdy Swoft
Purdy Swoft's Avatar
Sometimes removing the center brass bushing will help. The brass bushing was discontinued fairly early on , I forget the month and date but I usually don'y use it .
Old 01-30-2018, 12:41 AM   #17
redmodelt
redmodelt's Avatar
RE; I have purchased front engine mount springs from Snyders, Brattons and Sacramento Vintage Ford. All three suppliers sold springs that would not compress beyond 1" which makes the engine sit to high not allowing the crank to line up correctly with the crank nut.
What difference will it make if he orders different springs. Sounds like he is trying to crush the longer outer springs below the normal range.
Maybe posting of a photo of the springs installed might help point to something and also photo of the springs being using. There have been a number of suggestions and questions and none seem to be addressed.
If you have the brass bushing installed do you now have it on the top or underneath where it should be?
Last edited by redmodelt; 01-30-2018 at 10:50 PM. Reason: added something and changes somethings
Old 02-06-2018, 11:50 AM   #18
Dave1931Pickup
Thanks to everyone who replied with suggestions. I had to abandon this post after my wife tore her Achilles Tendon off of her heal and needed surgery. She is home now and doing well. No load bearing weight on her foot for eight weeks which is a problem living in a three story house.
After reading Steve's post about the springs they sell at Bert's I ordered a set. They truly are made to the original Ford specs. Attached is a picture comparing Bert's springs to another vendors springs. Bert's are the black ones. Below is a comparison of the two sets.
Bert's Zinc Plated Ones
Non Compressed Height 1.65" 1.60"
Fully Compressed Height .85" .97"
Wire Diameter .102" .112"
Compression Weight at 1.125" / 60 Lbs. 95 Lbs.
The biggest difference is the compresssion weight. The additional 35 Lbs times two is 70 pounds of force pushing up on the front of the engine causing it to sit to high in relation to the crank guide.
After installing the new springs the engine is sitting at the correct height and all is right with my world again. Now if my wife can survive my cooking everything will be great. Thanks to everyone, Dave
Old 02-06-2018, 12:02 PM   #19
Dave1931Pickup
My comparison chart didn't print the way I had it laid out. The first set of numbers are Bert's springs. The second set are the Zinc plated ones. Also the wrong Ford drawing was imported and I don't know how to fix it.
Old 02-06-2018, 12:39 PM   #20
700rpm
700rpm's Avatar
Thanks for the update. Bert’s is a good place.
You can edit your post by using the “go advanced” button after selecting “edit”.
Sorry to hear about your wife. Tell her good luck from us.
