First time putting coolant in my Flathead & heater core. Just got it hooked up yesterday. Should I just run water and flush it out or put a 50/50 green coolant mix and see how it goes? Thanks for the help.
I would run water until you are satisfied there will be no leaks or seepage inside or out.
Ok thanks. That seems like a good idea.
Mr Franklin is correct Water is a lot easier to clean up.
I agree but recommend (1) don't run plain water too long before getting some anti-corrosive protection and water pump lubricant in there, and (2) whatever antifreeze/anti-corrosive you finally put in, mix it using distilled water rather than tap water .... available at the supermarket; it's not expensive. Some may use premixed coolant but I don't think its worth the higher cost not to mix your own.
Also, if you have i.e. an aluminum radiator, it needs a special coolant. Last edited by Drbrown; 01-03-2018 at 12:33 AM. |
I like to mix my own so it reads -50 on my antifreeze tester, our weather here is cold, have had -35 to -40 in the past.
I got 3gl of green concentrate antifreeze & 3gl of distilled water and a bottle of water wetter will see if I have any leaks & look for gauges later.
buy an infarometer and use it to check temp since you don't have gauges.
Buy a digital temp gun even if you did have gauges.
You can check the temp of water at top and bottom of radiator. https://www.walmart.com/ip/Non-Conta...&wl13=&veh=sem Last edited by 19Fordy; 01-09-2018 at 07:05 PM. |
#11 | |
![]() Quote:
And what's with the nonsensical bold type?? |
Harbor freight has a digital heat gun for reasonable price. Every body should have one.
#13 | |
![]() Quote:
Didn't mean to upset you. I find that the bolder type makes it easier to read. Here's the new and improved temperature tool posting. https://www.walmart.com/ip/Non-Conta...&wl13=&veh=sem PS: When I was a youngster I used to let insignificant things annoy me. As I matured, I learned not to sweat the small stuff. Last edited by 19Fordy; 01-09-2018 at 07:40 PM. |
#14 | |
![]() Quote:
A transition from being the 'annoyed' to being the 'annoyer' ![]() ![]()
#15 |
I'm about 80 and too stiff to put my foot in my mouth. I find I should say what I intend to say two times to myself, sleep on it, then finally say it out loud. Just need to convince the Lady of the house to do the same.
#16 |
Thanks for the info. I will look at harbor freight I like there 20% off. Also have a buddy looking to see if he has any gauges laying around he doesn’t want. Took 4 gallons already and haven’t even started it up. Can you run mechanical temp gauges and the stock electric gauge ? I don’t think you can just wondering.
#17 | |
![]() Quote:
The problem is, just how innovative you can be finding or creating a place to mount the sending units. For example, I am running metal upper hoses (like pickup trucks) and the sending units are mounted in them.
#18 |
That’s nice. I saw some pictures of the thermostats in the water necks.
I also got a 4lb radiator cap tonight. The guy also gave me some Mercury Door sill plates |
#19 |
#20 |
I got a infarometer from Harbor freight temp was around 200. I have a crack in my thermostat housing need to get a new one. Now I was wondering what is the best one to get. Stock, chrome saw some with studs instead of bolts. Also my thermostat looks pretty outdated.
