Old 01-10-2018, 05:03 PM   #1
bonanza7369
Default seat belts
any one know if 1956 ford fairlane would have any factory provisions built into them for seat belt installation? I know they were an option just wondering if all cars had any mounting points in the floor.
Thanks Bill
bonanza7369 is offline   Reply With Quote
Old 01-10-2018, 06:20 PM   #2
Daves55Sedan
Daves55Sedan's Avatar
Default Re: seat belts
I believe '56 was the first year Fomoco offered seat belts as an option, but to my knowledge there were no factory knockouts in the floor panels for mounting. Apparently all seat belts back then were dealer installed. They punched holes in the floor and mounted the belts using big washers under the floor panels.
Be careful that you don't drill a hole through the floor in an area where a floor support structure is located underneath.
Old 01-10-2018, 09:06 PM   #3
Herman Munster
Herman Munster's Avatar
There was an installation kit that used special brackets and had a spec sheet with measurements where to drill the holes.
I have an NOS kit and a copy of the sheet somewhere.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Herman Munster is offline   Reply With Quote
Old 01-11-2018, 05:53 AM   #4
KULTULZ
KULTULZ's Avatar
Thumbs up Re: seat belts
There you go...
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 01-11-2018, 12:39 PM   #5
Ole Don
Ole Don's Avatar
Drill a small hole up from the bottom, then make it bigger from the top to avoid what Dave said in post two. Don't buy the cheap ones. I had some that unhooked themselves when I hit a bump. I then bought from Juliano's, a bit more money, but very nice to use.
Ole Don is offline   Reply With Quote
Old 01-11-2018, 01:22 PM   #6
Herman Munster
Here's some seat belt installation diagrams I've found. The front seat diagrams aren't very good. I'm still looking for the better ones I have somewhere.
There's a good one for the rear seats here: https://classiccarradiodoctor.com/fordseatbelts.htm
Old 01-11-2018, 03:57 PM   #7
KULTULZ
KULTULZ's Avatar
Post Re: seat belts
Tried to blow it up, didn't work...
Old 01-11-2018, 04:21 PM   #8
Herman Munster
I tried blowing it up first to see if it would post better but it didn't. I have a better scan somewhere as well as a paper copy. Still looking.
Old 01-11-2018, 06:22 PM   #9
Herman Munster
I tried uploading a couple better files plus a photo of the brackets.
Old 01-11-2018, 06:24 PM   #10
Herman Munster
For whatever reason something is limiting the file size when uploading them.
Old 01-11-2018, 10:16 PM   #11
miker98038
miker98038's Avatar
I can’t help with placement, but we just put a set of Juliano’s belts in my buddy’s 56 Nomad. First class stuff, buy the mounting hardware too.
Some years ago I bought the “correct” belts for a 56 for my 55 bird. Had the correct green color, and the fabric to metal buckle. I did not spend the uptick for the “Ford” logo on the buckle. They were expensive, but also first class. I’m not sure they show on the site, so try calling.
http://www.ssnake-oyl.com/mm5/merchant.mvc
miker98038 is offline   Reply With Quote
Old 01-12-2018, 01:18 AM   #12
dmsfrr
dmsfrr's Avatar
Try uploading the images one at a time. Sometimes if you select more than one image, and their file size is a bit large, uploading them at the same time seems to push the Barn server upload function past it's limit.
Old 01-12-2018, 04:23 AM   #13
KULTULZ
KULTULZ's Avatar
Question Re: seat belts
Is that an original FORD accessory set? Can you either show or post the FORD Part Number?
Old 01-12-2018, 04:25 AM   #14
KULTULZ
KULTULZ's Avatar
That's good info- THANX!
Old 01-12-2018, 11:40 AM   #15
Herman Munster
I'll see if the box has the part number. That was the photo I saved from the original listing.
Old 01-12-2018, 12:55 PM   #16
KULTULZ
KULTULZ's Avatar
I would greatly appreciate that.
Old 01-12-2018, 06:44 PM   #17
Herman Munster
Here's a photo of the box with the part number.
Something's not right with the upload process here. It only uploaded as a 33.3K file while the original photo size is 1.1M. It also uploaded rotated while it shows correctly for my computer. While it's adequate for this photo it does not allow for the full resolution of the installation instructions.
Old 01-13-2018, 04:36 AM   #18
KULTULZ
KULTULZ's Avatar
THANX!
That is the hardware kit (necessary part of correct install). The Basic PN for the actual belts is 61200.
Do you have both?
I have somehow lost my SNIP-IT TOOL. As soon as it is back up, I will post the MPC TEXT describing the belt kits. Most info (including illustrations) have been deleted from the 49/59 MPC ILL CATALOG.
Any chance of scanning (or having scanned) the instruction sheets (especially if 1956 copyright) and turning them into PDF?
BTW- Still hawking out your carb install ...
Old 01-13-2018, 07:11 AM   #19
bonanza7369
thanks for all the info guys
Old 01-13-2018, 01:20 PM   #20
Herman Munster
Kultulz, I don't have any NOS belts. The belts I have are good used originals but would probably need to be rewebbed.
I might have the instruction sheets scanned as a pdf but I'm not sure.
I've done a little work on the carb. I replaced the burned up choke tube that ran through the intake manifold so it may help solve my choke problem.
