A good used original GENERATOR cutout with Ford script and the letter B. It is round, and the mounting feet have round bolt holes. This type generator cutout was used from April 1936 through 1938. For your show car that cover will need to be replated. I have tested it with a simple continuity test and the testing current does not pass through it, because the points are open. This is a good sign it is OK as the points should only close in actual use. $25 + postage.
