Old 02-28-2012, 05:51 AM   #1
Pat Martone
Pat Martone's Avatar
Default Anyone using BOTH Mitchell Transmission and Overdrive units
I was wondering if anyone here is using BOTH the Mitchell transmission (with 1st and 2nd being synchro-ed and 15% higher gearing), along with the Mitchell overdrive?
(I realize that's a very expensive mod, almost $4300 for the tranny and overdrive units, and not including installation.)
I have heard from one owner that he got the Overdrive first and added the Mitchell tranny later and he felt the addition of the synchro-ed and higher-geared (1st and 2nd) tranny really improved his driving capabilities and enjoyment, and ability to keep up with traffic. I think he mentioned that when climbing hills and going from 2nd to 3rd, there was a problem with the original tranny, because the car would have to slow down too much while waiting for the correct rpm drop to shift into 3rd, if that makes sense?
Any comments would be appreciated.
Thank you.
Pat Martone is offline   Reply With Quote
Old 02-28-2012, 06:08 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Anyone using BOTH Mitchell Transmission and Overdrive units
Yeah, they work great together, ....if that is what the goal is. To me it solely depends on how you drive. Split-shifting with an overdrive works very well which effectively gives you 6 forward gears. Even if you had 15 forwards gears like some 18-wheelers do, would you have the perfect gear ratio all the time? Since I do not know the hill your friend speaks of, I cannot pass judgment however shifting back to 2nd with a non-synchro-ed transmission is easy enough to do if you know how. Using 2nd gear in O/D makes pulling a hill seem effortless.
Ironically, I hear about folks talk where they have an overdrive and an engine with a Tour regrind cam and they speak about how they must shift. If you have a good original or a Stipe IB series cam, then the torque of that cam allows the engine to lug down where the RPMs are low enough that it is super easy to drop back to 2nd. I say if you have the $4300, then go for it. Rarely do you ever hear of folks who removed their Mitchell O/D or Synchro unit because they did not like it!!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-28-2012, 07:16 AM   #3
Patrick L.
Patrick L.'s Avatar
I didn't know 1st and 2nd were synchro-ed, must be something new.. I'd certainly buy one if thats the way they now are..
Old 02-28-2012, 08:30 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Mitchell sells a syncro transmission and a syncro overdrive.
Old 02-28-2012, 10:51 AM   #5
Glenn C.
Glenn C.'s Avatar
The combination of the syncro trans and overdrive works great. We have the same combination on two of our heavy Fordors. Great for touring on any terain. You might as well inject a few $$ to the engine at the same time.
Glenn C. is offline   Reply With Quote
Old 02-28-2012, 11:00 AM   #6
Glenn of northport
Glenn of northport's Avatar
Wink Re: Anyone using BOTH Mitchell Transmission and Overdrive units
I have mitchell syncro trans in2 ofmy cars and they are great going up and down hills also makes it easy for my kids and grand children to drive .
Glenn of northport is offline   Reply With Quote
Old 02-28-2012, 11:07 AM   #7
1930artdeco
1930artdeco's Avatar
Around here the tranny would be of great importance-not from the hills but from the stop lights. The lights here will change on you in a split second from green to red bypassing yellow. So the synchro 3rd to 2nd would be great.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-28-2012, 11:55 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I believe Pat meant to say 2nd and 3rd are syncro in the Mitchell tranny.
Old 02-28-2012, 01:03 PM   #9
V4F
V4F's Avatar
they make an all synco 4 speed with 4th as a od .
sorry , not mitchell
V4f
V4F is offline   Reply With Quote
Old 02-28-2012, 01:16 PM   #10
BRENT in 10-uh-C
Mitchell does?
BRENT in 10-uh-C
Old 02-28-2012, 02:00 PM   #11
CarlG
CarlG's Avatar
That's gotta be the F150 conversion
Old 02-28-2012, 02:16 PM   #12
Ronnie Lawson
Ronnie Lawson's Avatar
I have just completed restoration of a 1929 Town Sedan. I put both Mitchel Transmission and Overdrive in and I really like them. I have driven over 4000 miles since I installed them. I also have to 4-11 rear end. I have plenty of power on take off and I don't do bad on top end. I have has her up to 70 mph and it is there if I need it. I don't recommend driving at 70 mph in a Model A.
I also have the touring engine in with the 6:1 Snyder head.
Ronnie Lawson is offline   Reply With Quote
Old 02-28-2012, 04:34 PM   #13
buyitsmart
buyitsmart's Avatar
I have both the Mitchell (synchro 15% 2nd, 3rd, and reverse) transmission and the OD but haven't installed them yet...been too busy. Just got done with the Snyder 6.1 HC head and love the difference it made.
Fix it like you know you're gonna drive it.
buyitsmart is offline   Reply With Quote
Old 02-28-2012, 05:27 PM   #14
PO51
PO51's Avatar
Does anybody know the website fot the Mitchel syncro tranny?
PO51 is offline   Reply With Quote
Old 02-28-2012, 06:15 PM   #15
Mike V. Florida
This may help;
http://www.model-a-autoparts.co.nz/overdriver.php
Old 02-28-2012, 07:49 PM   #16
Mike_Ovale
Mike_Ovale's Avatar
Hi:
I have a 26% Mitchell overdrive with a 15% 1st & 2nd gear 2nd & 3rd (only) is synchronized Mitchell transmission in my 28 Tudor. My Model A gets a lot of touring miles on black top & dirt back roads and is a pleasure driving on any road. Good on long grades with a selection of gears to get up the hills. Shifts fast keeping your momentum up. I use 3.78’s and the car runs along on highways with ease. Installing is a snap everything fits like it should. Pulling the pinion gear is hardest job.
Mike
Mike_Ovale is offline   Reply With Quote
Old 02-28-2012, 07:54 PM   #17
CarlG
CarlG's Avatar
Originally Posted by Mike_Ovale View Post
... Pulling the pinion gear is hardest job.
Mike
Did you use the Pinion Puller that Mitchell sells/rents?
Old 02-28-2012, 09:19 PM   #18
columbiA
I find that the stock trans will shift fairly fast up or down if it,s double clutched.For me at least,a lot of the charm of the A is lost when you go to a synchroed trans,although it makes it easier for women to drive.
columbiA is offline   Reply With Quote
Old 02-28-2012, 10:21 PM   #19
msmaron
msmaron's Avatar
What does the synchro overdrive do??
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 02-28-2012, 10:41 PM   #20
Logan
Logan's Avatar
It allows you to shift into/out of overdrive with only clutching once. If you get good at it and can judge rpm you dont have to clutch while engaging overdrive.... But then again, its not hard to shift the standard model a tranny without clutching also.
Cowtown A's
Logan is offline   Reply With Quote
