Old 09-03-2017, 01:12 PM   #1
war2guy
Default rear wheel bearing replacement
I have a 31 model A with the rear hubs disassembled. I purchased new seals that go between the bearing and snap ring, but there is about another 1/4 " of space in the hub. What part am I missing? Is it the felt washer I've seen reference to? One print I've seen shows a felt on each side of the bearing but no seal. Again, the only parts I have to install in the hub are the bearing itself, the seal and the snap ring. Please help.
war2guy is offline   Reply With Quote
Old 09-03-2017, 01:55 PM   #2
BillCNC
BillCNC's Avatar
Default Re: rear wheel bearing replacement
Hi war2guy,
I'm at the same place with mine today so I looked at a couple of drawings, It shows nothing but the bearing but I'm new at "A's" so I could be wrong.
Rear End https://www.brattons.com/assemblies/...-assembly.html
Rear Brakes https://www.brattons.com/assemblies/...sembly-16.html
Regards
Bill
BillCNC is offline   Reply With Quote
Old 09-03-2017, 02:56 PM   #3
J Franklin
J Franklin's Avatar
Tap the seal in just enough to install the snap ring. You don't want the bearing trapped by the seal.
Old 09-03-2017, 05:59 PM   #4
Al 29Tudor
Al 29Tudor's Avatar
That's about right. There is more room than you would expect.
Al 29Tudor is offline   Reply With Quote
Old 09-03-2017, 08:20 PM   #5
supergnat
supergnat's Avatar
I bought the seal installation tool from Brattons. It works great. REAR HUB SEAL DRIVER -
Use this tool to help you install the grease seal #1560 to the correct depth for the snap ring installation. Tool only no seal. 1560T 28-31 $19.95ea.
Supergnat
supergnat is offline   Reply With Quote
Old 09-04-2017, 07:02 AM   #6
kenparker
kenparker's Avatar
To reiterate ( that's one of my fancy college words), you do not press the seal all the way to the bearing. You want some space between bearing and seal so bearing can "float". Press seal in just far enuff ( another college wurd) to clear the snap ring.
Never thot about it but the idea to grind off the backwards bevil so snap ring pliers will work is a good one. thnks. ken
kenparker is offline   Reply With Quote
Old 09-04-2017, 12:01 PM   #7
JBill
Wear eye protection when reinstalling that snap ring!
JBill is offline   Reply With Quote
Old 09-04-2017, 06:18 PM   #8
war2guy
Thanks very much for all of your help. I think I'm good to go!
Old 09-04-2017, 08:51 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Hand pack the bearing with Mystik JT-6 High Temp Red grease, and you should be good to go for years. Don't use the grease zerk.
