So I dug through my collection of odd's and end's and found this. It's 15/16 outer diameter, 7/8 inner diameter and 1/16 wide. Am I in luck?
I went to pep boys and they hooked me up with a metric one and it is working for me.
Looks good to me. Does it fit the drain plug?
Thought I heard that a spark plug washer would work as well? Jeff
Let's let pylons, be pylons! |
In a pinch, just rub #2 Permatex on the plug threads.
Bill W.
Land Rovers use the same one.
I had the same problem,would leak with the washer installed. Took it off and had no leak.
When you guys say fiber washer, what exactly are we talking about?
The A vendors sell them either alone or in the kits. They are a hard usually gray or black composition material, not cork. see post 9.
I believe the originals are the same as the Spark Plug gasket.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
Thanks guys....
