Old 07-27-2017, 10:50 PM   #1
Rustedjunk
Rustedjunk's Avatar
Default 1947 Tudor Clock Wiring
Okay, I don't get it. What's missing? Is it a fuse? If so, what kind and amp?
Rustedjunk is offline   Reply With Quote
Old 07-28-2017, 03:00 AM   #2
FortyNiner
FortyNiner's Avatar
Default Re: 1947 Tudor Clock Wiring
The wiring diagram shows three connections for the clock : light power tied to the dash dimmer swich, a ground, and a fused power line for the clock itself. Haven't seen a spec for the rating but as the line is connected to the lighting breakers, I would believe that we're looking at 2 amps or less.
Old 07-28-2017, 04:57 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
There are just two wires to the clock. One for power and one for lighting.
All grounding is thru the body.
Old 07-28-2017, 05:31 AM   #4
Rustedjunk
Rustedjunk's Avatar
Is it a three amp fuse I can get at the auto parts store?
Old 07-28-2017, 06:00 AM   #5
weemark
http://www.macsautoparts.com/ford_me...eces-ford.html
weemark is offline   Reply With Quote
Old 07-28-2017, 07:09 AM   #6
Rustedjunk
Rustedjunk's Avatar
Originally Posted by weemark View Post
Thank you all for the information.
Old 08-01-2017, 01:42 PM   #7
Rustedjunk
Rustedjunk's Avatar
Since my car is 12V, do I want to put the same kind of voltage reducer to the clock like I did with the gauges?
