Old 07-24-2017, 08:57 AM   #1
W1964
Default Throttle Linkage "too short"
The throttle linkage on my 39 does not provide enough travel to get full throttle from the carb. Are there different lengths of rods that connect to the carb ? What's the solution? Your help is much appreciated.
W1964 is offline   Reply With Quote
Old 07-24-2017, 09:42 AM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: Throttle Linkage "too short"
It is possible to perhaps get a longer linkage. Standard is around 10.5 inch.
I have one which I can adjust as both ends fit into a centre threaded section which allows correct length to be found for full throttle position. Or you can perhaps after careful measurement cut the rod and add required extension as to give full travel
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 07-24-2017, 09:52 AM   #3
19Fordy
19Fordy's Avatar
Could you cut the rod, thread it and add a coupler as shown here?
The coupler is easy to make if you have a drill and tap and die.
This has been working fine for last 15 years.
19Fordy is online now   Reply With Quote
Old 07-24-2017, 10:11 AM   #4
tubman
tubman's Avatar
I have an adjustable one like Phil described on my '51 Ford. I think all 8BA's had them.
Old 07-24-2017, 10:25 AM   #5
JSeery
JSeery's Avatar
Should be able to purchase a couple that would work at a hardware store and then thread the rods to match it.
Old 07-24-2017, 11:41 AM   #6
6lucky13
6lucky13's Avatar
As indicated above, the standard accelerator rod is about 10.5" (10.06" from center lines of holes). If you have a V8-60 then it would be 8.44" from center lines of holes.
Kerry
6lucky13 is offline   Reply With Quote
Old 07-26-2017, 10:02 AM   #7
1948F-1Pickup
1948F-1Pickup's Avatar
I have an adjustable one on the truck. Threading the rod was a cake-walk.
Finding a coupling nut was a bit more difficult.....
1948F-1Pickup is offline   Reply With Quote
