Standard 4 banger engine in my 31 coupe. The plugs look good and so do the points. When it warms up a little it starts missing /stumbling when I step on it a little. The manifold vacuum tube is not loose or leaking. It starts and idles fine. Maybe needs a new condenser...is there an easy way to know other just replacing it? Any other ideas? Worried it's going to die out completely on the road one day!
John the Model A Rookie from North Carolina |
How old is the distributor body and rotor? If you have one of the Red distributor bodies they are known for jumping spark between 1&2 and between 3&4 internally, so it could be the problem.
Where is the GAV set? If it is more than a full turn open it can cause too much gas into the engine, which can cause a coughing.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
If the spark is wimpy yellow, then try a new condenser. If that doesn't help, then try another coil. |
