Old 06-09-2017, 08:47 AM   #1
LEAZER48
Default master cylinder rebuild
I rebuilt the master cylinder on my 48 coupe, cleaned and honed the cylinder (on bench vise), soaked the kit parts in clean fluid, installed the kit, added clean fluid to reservoir and waited for leaks, after a few minutes it started leaking through the front, what did I do wrong?
LEAZER48 is offline   Reply With Quote
Old 06-09-2017, 09:39 AM   #2
chap52
chap52's Avatar
Default Re: master cylinder rebuild
I usually rub a little grease on the edges of the rubber seals when installing into a clean, dry cylinder both master and wheel cylinders.
Old 06-09-2017, 09:57 AM   #3
Bob C
When you say FRONT do you mean where the brake lines connect?
Bob
Old 06-09-2017, 10:11 AM   #4
flathead4rd
flathead4rd's Avatar
Bob
That was my question also. Plus, grease on a rubber part? Not a good idea.
flathead4rd is offline   Reply With Quote
Old 06-09-2017, 10:11 AM   #5
LEAZER48
No, front on my car means where the push rod for brake pedal is inserted
Old 06-09-2017, 10:24 AM   #6
Terry,OH
Terry,OH's Avatar
Is the end washer in place? just before the snap ring?
Old 06-09-2017, 10:28 AM   #7
LEAZER48
Yes
Old 06-09-2017, 08:22 PM   #8
BL in NH
instead of grease, lube the seals and cylinder walls with brake fluid.
BL in NH is offline   Reply With Quote
Old 06-09-2017, 08:27 PM   #9
jake197000
maybe you folded the seal over.take it back apart if its not torn you can prbably reuse it.
jake197000 is offline   Reply With Quote
Old 06-09-2017, 10:54 PM   #10
LEAZER48
Thanks Jake, I took everything apart applied brake fluid to the parts put it back together, no leaks, I think the first seal was not seated all the way.
