Old 06-03-2017, 02:43 PM   #1
davehc
davehc's Avatar
Default Dome Switch Plate Hole Dim.'s
Can someone tell me the screw hole dimension from center to center for the dome light switch plate for a 30 Town Sedan that go's on the door post ? I am trying to make sure I have a switch that I have would work , before buying one . Thanks
davehc is offline   Reply With Quote
Old 06-03-2017, 03:43 PM   #2
Gunmetal blue2
Gunmetal blue2's Avatar
Default Re: Dome Switch Plate Hole Dim.'s
The switch is fastend with two wood screws. The inportant part is there enough room for the switch to fit were it goes and a grove in the wood for the wire. My 29 it was about a inch to 1 1/4" apart.
Gunmetal blue2 is offline   Reply With Quote
Old 06-03-2017, 08:02 PM   #3
Don Turley
Don Turley's Avatar
Original dome light switch plate mounting screws are one and one-half inches ( 1-1/2" ) apart. Reproduction switch plates are not correct in size or appearance. The mounting screw distance on the reproduction switch is not the same as an original switch plate, but can be modified to fit. I do not have on hand the reproduction parts to measure. I have an original restored switch plate available. If you are not particularly concerned about originality and only want function, you can make the reproduction parts fit.
I found one of the reproduction switch plates and the mounting screw distance is one and three-eights inches ( 1-3/8" ).
Don Turley
No FordBarn Messages.
Email: [email protected]
Call: 706-589-0738 (GA) Unless otherwise noted, prices include shipping to a USA address & paid with check or USPS money order or PayPal. Contact me before paying. Everything that I sell comes with a guarantee. Return unaltered within 10 days for refund.
Don Turley is offline   Reply With Quote
