Old 05-20-2017, 07:08 PM   #1
Bob Leonard
Default Stuck oil pump
About two years ago, I started a project to restore my 1931 Roadster with my son and grandson. It has not run for five years. Well, life got in the way and we are starting over.
One of the things that I wanted to do is to remove and clean the oil pan as I suspected it could be pretty sludged up. We removed the pan and the oil pump should have dropped out per my Les Andrews Mechanics Handbook No. One. It did not. In fact, it doesn't even wiggle a little.
Am I missing something? What should I do? Since it appears to be stuck, I assume that it would be bad to just leave it in and replace the pan.
By the way, the oil wasn't even a little sludgy.
Thanks, Bob
Bob Leonard is offline   Reply With Quote
Old 05-20-2017, 07:59 PM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Stuck oil pump
Look at the outside of the block near the pump and make sure there is not a set screw or something like that holding the pump in place. There should be a small pipe thread plug in that hole. Good luck.
Old 05-20-2017, 08:11 PM   #3
1955cj5
1955cj5's Avatar
A good place to start...Here is a picture with the pump holding tool in place....
If there is something in that hole I would remove it then try again to free the pump...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-20-2017, 08:13 PM   #4
2manycars
2manycars's Avatar
The pump should come out without much resistance. If you cannot pull it out, remove the drive gear assembly by removing the large spring that holds it in place, and pulling it up and out. You can then tap out the pump from the top with a brass punch or drift.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 05-20-2017, 08:20 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Did you remove the dip tray to make sure the very bottom of the oil pan was clean?
Old 05-20-2017, 08:25 PM   #6
eagle
eagle's Avatar
Why do you want to take it out? If the only purpose of removing the pan was to clean it, put it back on with the oil pump in place.
Old 05-21-2017, 01:15 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Vermins' oil pump locating dowel was PEENED over, so the oil pump wouldn't fall on your HEAD!! ALSO, the oil pump drive had NO SPRING holding it in, BUT wouldn't budge out of the block????
Bill Slightlypuzzled
"THE ASSISTANT GURU OF STUFF"
Old 05-22-2017, 07:37 AM   #8
Growley bear
I you do want to remove the pump for inspection which is a good plan if you have no idea of its condition, make sure that you put something under the pump or have a helper hold it. If it drops out and falls on the floor it could become damaged.
Growley bear is offline   Reply With Quote
Old 05-22-2017, 01:29 PM   #9
Brentwood Bob
the screen can be plugged and restrict the pump. Just because the oil was clean you may miss what is under the insert. New gaskets are a good thing.
Also, the oil pump was designed to be held in position by the spring between it and the bottom of the oil pan. I have seen various methods to hold it in place, all were not as original, and I wonder if holding the pump ridigidly in position was a good thing.
several reasons to do the job right.
Brentwood Bob is offline   Reply With Quote
Old 05-22-2017, 02:30 PM   #10
SeaSlugs
SeaSlugs's Avatar
or someones tapped that pipe plug hole straight and the plug is now hanging up the pump. yes it should just plop out with the slightest wiggle.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
