Old 05-19-2017, 09:57 PM   #1
DaveWright
DaveWright's Avatar
Default Piston stampings...?
Newbie here, looking for a little help with my A: While tearing down my 1930 engine, I found (only) one piston to have the following stampings on the top of it: .002 1/2, X38, 21, and a 1 in an oval. What do any of these numbers mean? If the one is indicative of a bore of .0025, does that mean that only that piston has been replaced (and only that cylinder has been bored)? Is boring one cylinder during a repair a typical remedy in the past?
Any help or insight is greatly appreciated.
Thanks!
DaveWright is offline   Reply With Quote
Old 05-19-2017, 11:14 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Piston stampings...?
Yes, it was.
Best to measure each bore to truly see what you have.
Old 05-20-2017, 07:46 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
It was just honed for the small oversize. It was likely just lightly scratched, or maybe the engine seized on that one piston, and needed a good honing to clean the bore.
Old 05-20-2017, 11:15 AM   #4
100IH
Long ago, many larger shops had piston grinders, and semi pistons were a warehouse item. Re-builders could bore a block and if one hole did not clean up, they could go slightly bigger and use a semi piston sized to fit without the hastle of going back to the other holes to match them to a larger set, and not remove more iron. Also, back then, balancing equipment was a rarity.
100IH is offline   Reply With Quote
Old 05-20-2017, 06:34 PM   #5
DaveWright
DaveWright's Avatar
Thanks for the info, gentlemen! Much appreciated. More questions to come as I continue with this project...
Old 05-21-2017, 09:35 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
Usually a .0025 piston was put in a worn bor to stop piston slap, but many times the bore was worn much more, I have seen as much as .040 at the top, tapering down to .002-,005 at the bottom---measure the bores for taper
