Old 05-15-2017, 07:32 PM   #1
Old Henry
Old Henry's Avatar
Default How to remove pilot bearing? '47 59A engine
Without removing flywheel? I'm just ready to install VanPelt's rebuilt tranny. He sent a new pilot bearing but I haven't figured out how to get the old one out without removing the flywheel, which I won't do. (I'll leave the old one in that seems fine if I can't get it out.)
Any ideas?
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 05-15-2017, 07:48 PM   #2
scicala
scicala's Avatar
Default Re: How to remove pilot bearing? '47 59A engine
The way I've always done it (without a puller), is to keep feeding wet toilet tissue into the hole in the center of the pilot bearing and us a punch the same size as the hole to keep packing it in there with a hammer. Eventually the hydraulic pressure will push the pilot bearing out. Sounds a little weird, but works every time.
Sal
scicala is offline   Reply With Quote
Old 05-15-2017, 07:48 PM   #3
JSeery
JSeery's Avatar
I always use a slide hammer. You need a hinged T fitting you can get to go through the bearing and catch the back side. Sometimes you can use an L fitting if you work your way around and just move it a little in each position.
Another method is similar to what scicala posted but using grease. The punch needs to be a fairly close fit to the ID.
Old 05-15-2017, 08:01 PM   #4
Talkwrench
Talkwrench's Avatar
You can also pack the hole full of grease and with a suitable sized punch give it a good tap in the hole and it will start backing out just push more grease in and keep going.
Old 05-15-2017, 08:26 PM   #5
Old Henry
Old Henry's Avatar
Or, you can just go down to AutoZone and rent the right tool (for free) and get the job done. (Did JSeery mention slide hammer?)
Old 05-15-2017, 08:29 PM   #6
38bill
38bill's Avatar
[QUOTE=Old Henry;1473019]Or, you can just go down to AutoZone and rent the right tool (for free) and get the job done.
Sure, but whats the challenge in that. Besides I bet you barely got any dirt under your fingernails.
38bill is offline   Reply With Quote
Old 05-15-2017, 08:34 PM   #7
Greg58
Greg58's Avatar
Long before we had tool rentals I too used the grease method, times are better now that stores like auto zone offer the tool rentals.
Greg
Greg58 is offline   Reply With Quote
Old 05-15-2017, 08:34 PM   #8
Old Henry
Old Henry's Avatar
[QUOTE=38bill;1473021]
But, I did get a big blood blister from the 5 lb. sliding hammer sliding down and smashing my thumb. Does that count for anything?
Old 05-15-2017, 08:58 PM   #9
Bored&Stroked
Bored&Stroked's Avatar
[QUOTE=Old Henry;1473025]
Yep - it counts for you probably won't do it next time! LOL
Old 05-15-2017, 11:17 PM   #10
rg130
rg130's Avatar
I've seen a video where slices of bread is packed into the hole using a punch and hammer. Works like hydraulic pressure which forces the bearing out
rg130 is offline   Reply With Quote
Old 05-16-2017, 05:09 AM   #11
Kerk
WOOD dowel and grease works for me. kx
Kerk is offline   Reply With Quote
Old 05-16-2017, 06:27 AM   #12
Frank Miller
Frank Miller's Avatar
I like the tissue paper idea as it sounds less messier than the grease.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 05-16-2017, 07:28 AM   #13
chap52
chap52's Avatar
Lots of these methods can be see on You Tube. Just did it but I wimped out and used a small puller which I got on Amazon.com. Can't ever have too many tools. Let my son figure some of the obscure ones out after he inherits them.
I have actually tagged a few odd ones and home made ones with descriptions of there use. They are in the bottom drawer and I may never have the need to use them again. Kinda cool!
Old 05-16-2017, 08:23 AM   #14
38bill
38bill's Avatar
Ouch!! For that you get the "Busted Knuckle" award!
Old 05-16-2017, 08:38 AM   #15
fordwife
One thing I learned about slide hammers years ago: Be careful how you hold it before you start use it. Saves a lot of unnecessary pain.
fordwife is offline   Reply With Quote
Old 05-16-2017, 08:48 AM   #16
Ole Don
Ole Don's Avatar
You don't have the correct size punch? Start with a big bolt, and wrap tape around it until it fits close to the diameter of the ID. I used grease, but the wet TP sounds easier for clean up.
Ole Don is offline   Reply With Quote
Old 05-16-2017, 09:00 AM   #17
Bruce Lancaster
You like road trips...pop over to New Jersey and I will popitoutathere with the proper KR Wilson tool!
Old 05-16-2017, 09:32 AM   #18
markdtn
markdtn's Avatar
It's a big ole bearing. Slide hammer should work fine. This is an 8BA but same bearing and very similar flywheel.
markdtn is offline   Reply With Quote
Old 05-16-2017, 09:37 AM   #19
Bruce Lancaster
Slidehammer with just a hook will do fine, actually, it's not a super tight press in there.
On the grease and toilet paper options...someone on the HAMB took that to a perfectly developed level: Use peanut butter instead of grease. Knock the thing out, then go have a cup of coffee while your dog cleans everything up perfectly!
Old 05-16-2017, 02:06 PM   #20
Flathead Fever
Flathead Fever's Avatar
This is the hot ticket. I have probably pulled 100 pilot bearings over the years. It yanks them right out, fast. You screw down the handle which pushes a tapered shaft down between those two arms so the ends are held in place in back of the pilot bearing. Then you start turning the nut and it pulls it right out. I have never tried one of these tools on a flathead but it worked on everything I ever replaced a clutch in at work.
Try and get a used Snap-On pilot bearing puller (A-78) its the best but they are not cheap. I checked the "sold" ones on eBay and they went for between $42.00 to $100.00. Keep an eye out for these at the swap meets.
