Old 04-01-2017, 12:34 AM   #1
Chris Haynes
Chris Haynes's Avatar
Default Bumpers rechromed?
My newly acquired 1930 Tudor's bumpers have been painted. Most Model A's I see have obvious reproduction bumpers on them. Is there some reason they don't have them re-plated?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-01-2017, 01:19 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Bumpers rechromed?
Seven years ago, Paul's Chrome in P.A. did a set rear bumpers for peters180a/170b at $300.00 per bar times 4 bars. Yup $1200.00 for the rears.
Old 04-01-2017, 02:27 AM   #3
Beauford
YIKES!! Looks like I should stay with the rest of my vehicles theme...."Rusty"
Beauford is offline   Reply With Quote
Old 04-01-2017, 05:05 AM   #4
Bruce of MN
Bruce of MN's Avatar
These were recommended by someone in my Triumph club as being reasonably priced (still may be surprisingly big bux!):
http://www.chevychaseplating.com/
http://metroplating.com/
http://www.hanlonplating.com/
Old 04-01-2017, 09:16 AM   #5
Larry Jenkins
A great case for good quality stainless steel bumper bars..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 04-01-2017, 09:24 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
That is way out of line because only the face needs to be polished smooth, and I wouldn't take the rivets out since that end is all black paint. I would sandblast the bumpers and polish the face myself, then take them to the plater. Of course if you have deep pits that need to be filled that would be different, and I'd be looking for a better set.
Old 04-01-2017, 10:42 AM   #7
H. L. Chauvin
Try calling Mr. Steve at Bert's.
Sometimes they have people who offer different Model A services off and on ..... sometimes not ...... just pot luck ..... depends on gravitational tidal moon forces and Global Warming temperatures of individual residual brain moisture.
Appears people who do any kind of specialty Model A work just come and go in different moon phases ....... work for a spell .... then no more ...... then somebody else may knock on their door asking for work.
Had bumpers and gear shift lever re-chromed at Bert's a few years ago when the moon was right .... excellent job ..... just never give up & keep asking .... one thing for sure ..... your answer will always be "NO" if you quit asking !!!!!!
H. L. Chauvin is offline   Reply With Quote
Old 04-01-2017, 12:47 PM   #8
Capt Quahog
Capt Quahog's Avatar
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
In this day and age . . . it is no doubt far cheaper and much less trouble buying NEW bumpers than trying to get anything re-plated. As with most things in the USA within recent decades, the Fed government though EPA rules has greatly restricted such operations as metal plating. Just last night I happened to be looking online at Mike's A Fordable parts and saw brand new "stainless steel" Model A Ford front bumpers for just over $300. The chrome versions were less.
I wouldn't be so paranoid if people weren't plotting against me all the time
Capt Quahog is offline   Reply With Quote
Old 04-01-2017, 01:09 PM   #9
Kevin in NJ
Some notes on bumpers.
The back sides get their color from the original process. During A production there was no bright nickel. So the dull nickel needed to be polished before chrome plating. Only the front was polished. The back side would look like the back side of aluminum foil. Also the back of the bumper would have mill scale, so they would not be smooth.
Very few shops have the correct tank to do this process. Paul's has the tank, but the guy says he could never get it to work right. Based on how they messed up my plating they just have troubles. Frankford plating near Phliadelphia I know has the correct tank and can do the correct process.
Old 04-01-2017, 03:10 PM   #10
Beauford
Bruce of MN....looks like Hanlon is in our backyard. I'm 20mins North of Richmond.
Old 04-02-2017, 04:45 AM   #11
Bruce of MN
I hope it works out for you. Some of the above tips on what should actually be polished can avoid wasted labor by you or the shop.
My rear bumpers need replating, so I may see how the job using the above tips compares to a new stainless set in cost.
Old 04-02-2017, 06:12 AM   #12
updraught
updraught's Avatar
Spring steel?
updraught is offline   Reply With Quote
Old 04-02-2017, 06:20 AM   #13
captndan
captndan's Avatar
I don't know all the little details of replateing. I priced mine from all local chrome shops and got new ones at Bert's for almost half the price. And no 3-6 month wait. I"m very happy with what I got.
captndan is offline   Reply With Quote
Old 04-02-2017, 06:50 AM   #14
ford-m
ford-m's Avatar
I'm in this problem myself, plater wanted $1000 bucks a piece for the rears.
Stainless units are NOT in stock anywhere.
So I painted mine for now.
ford-m is offline   Reply With Quote
Old 04-02-2017, 10:56 PM   #15
Mike V. Florida
Out of line? Not so sure see ford-m's quote.
Old 04-02-2017, 11:43 PM   #16
Tom Wesenberg
Yep, now there are 2 platers with prices out of line.
Old 04-03-2017, 04:16 AM   #17
Alaska Mike
A local powder coat shop says they can do powder coat chrome. I am sending some motorcycle pieces over to see how they come out. I will let you know how it looks.
Alaska Mike is offline   Reply With Quote
Old 04-03-2017, 05:08 AM   #18
ronn
their plating is very inexpensive and the quality of the end job is there to prove it...............
great for a "quick" clean up. laughter will follow you at shows.
Old 04-03-2017, 06:59 AM   #19
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I would consider Mikes advice about the powdercoating if you are looking for a driver and don't want to stick with silver paint. I saw an exhaust manifold at the powdercoaters that had a good sheen to it, looked like porcellenizing with a good silver gloss and should stand up better than silver paint.
Barry B./ Ma. is offline   Reply With Quote
Old 04-03-2017, 07:43 AM   #20
Keith True
Keith True's Avatar
I saw some of the newer 'chrome' powdercoating on a 46 Chevy grille and bumpers.I was real impressed with it.It looks like older,or aged chrome.It fit the car it was on perfectly.I'm going to use it on a front bumper for an A pickup.I do remember Pete Mendola talking about getting his chrome done for his 180-A.He found a shop that was willing to do the work to his specs as long as he was willing to step up to the plate and pay for their time.He stepped up and they produced.
