Old 03-31-2017, 09:01 PM   #1
51504bat
51504bat's Avatar
Default School me on V8 60's
Looking at a V8 60 for a potential project but I barely know enough to keep the 8ba in my '39 p/u running so 60's are completely new to me. I searched the forum and came up with some info on water pump issues but not much else. The engine is complete except for a carb from what I can tell. Heads and intake are off. No visible cracks but one cylinder got water in it, possibly from a blown head gasket. It doesn't appear that the damage went through the sleeve. All cylinders are sleeved. There may be a rebuild tag on the bell housing portion of the block but its unreadable. Obviously it will need a complete overhaul. Any specifics to look for or versions to stay away from? The intake is aluminum and a single carb. I believe these used a model 81 carb? Are parts as readily available as a 59 or 8ba? Thanks in advance.
Old 03-31-2017, 09:05 PM   #2
Charlie Stephens
Default Re: School me on V8 60's
Why don't you tell us what the potential project is and that will determine the responses.
Charlie Stephens
Old 03-31-2017, 09:16 PM   #3
aonemarine
aonemarine's Avatar
Pucker up! Its about to get even more expensive. Parts are scarce and costly when you do happen across them. They dont make alot of torque, never will. Make sure this is the path you want to travel before heading off on the journey..
aonemarine is offline   Reply With Quote
Old 03-31-2017, 09:42 PM   #4
51504bat
51504bat's Avatar
Charlie Stephens
Thinking about a single seat speedster type for Trog.
Old 03-31-2017, 10:07 PM   #5
tubman
tubman's Avatar
There are two basic versions; the "Tin-Side", with electrically welded sheet metal sides and those with regular cast iron blocks. I believe that the "Tin-Sides" were early, 1937 and perhaps early 1938. I have heard that the "Tin-Side" may have problems with the sheet metal sides deteriorating and leaking. The only "60" I ever had didn't have those problems (but that was in 1961). 1940 Models are a little different, with larger bearing journals. If you are still interested in them, try to find some guys running them in "Midget" racers in vintage meets. Those guys are really into them and know their stuff. Surprisingly, Speedway Motors still has high compression heads and dual carb manifolds for them.
Old 03-31-2017, 10:17 PM   #6
Mike in AZ
Mike in AZ's Avatar
check out H&H flatheads....they have parts and prices for you....sounds like it could be a fun project....early Ford in San Dimas had '39 trans for the 60....i think....a few years ago, tho.....have fun....Mike
Mike in AZ is offline   Reply With Quote
Old 03-31-2017, 10:20 PM   #7
Charlie Stephens
Is it safe to assume that you are dealing with a cubic inch requirement? I am not familiar with the TROG rules.
Charlie Stephens
Old 03-31-2017, 10:35 PM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Try to find a copy of this book.... "The V8-60 Ford's Little Powerhouse" .... by Richard Willim.
You might find a copy on ebay or you could put a wanted ad here, and maybe someone will have a copy they are willing to sell.
https://www.fordbarn.com/forum/showth...t=marty+willim
https://www.fordbarn.com/forum/showth...ht=rich+willim
John
Old 04-01-2017, 08:20 AM   #9
62pan
If you can find Richard Willim's book that would be a big help. The early 37's have the tin sides while the later 37's thru 39's are all cast. All parts should interchange with these models. The 40 is a different model, larger crank bearings, different block, longer crank snout etc. Parts for the 40 are really hard to find. Midget guys loved these. There is also a French version so if you post a photo of what you found that would help.
Your project sounds interesting just beware that a lot of guys are going to try and talk you out of using a V8 60. A lot of negativity shows up when ever they are talked about. I stuck one in a motorcycle based on the 38 Indian Four. Theres a photo on the barn somewhere. Good luck.
62pan is offline   Reply With Quote
Old 04-01-2017, 09:20 AM   #10
aonemarine
aonemarine's Avatar
There is also a facebook group; V8-60 fords little power house
Its worth signing up for
Old 04-01-2017, 01:53 PM   #11
drolston
drolston's Avatar
In 1971 I bought a '37 Tudor slant back just for the looks of that model. The V8 60 in it was pretty tired. I replaced it with a used motor that came out of a boat. It still would not pull the hat off your head. Even then parts for an overhaul were too expensive for my budget. With three kids in diapers and a starter job, I couldn't even afford a new fuel pump. My wife had hysterics when she caught me blowing on the gas filler to get fuel to the carb (yes, it works, but your face looks funny for a while). Sadly, the '37 had to go.
I just spent twice the cost of a 300 hp crate engine to get my 59A/B from 95 hp to maybe 170 hp, because I love the look and the sound of a full dress flathead. It can't beat my minivan in a drag race, but the fact that many others appreciate the results, helps. So my advice is: If you love your vision of the completed project, go for it. But the only other people that appreciate a V8 60 are antique midget racers.
Old 04-01-2017, 05:24 PM   #12
51504bat
51504bat's Avatar
Thanks everyone for the good advice and info. Turns out the project I was interested isn't going to work out so I'll keep looking for some type of speedster project maybe a banger or a 239 flattie, just depends.
Old 04-01-2017, 11:37 PM   #13
Curt in AZ
Curt in AZ's Avatar
My goto site for old books is abebooks.com, but no luck on the Willim book. But there is a 1936? Ford publication on the V8 60 that might be helpful:
https://www.abebooks.com/servlet/Boo...%26sortby%3D17.
Curt in AZ is offline   Reply With Quote
Old 04-02-2017, 09:41 AM   #14
flatjack9
flatjack9's Avatar
Willim's son is working on a reprint of the book.
