Old 03-25-2017, 10:07 PM   #1
Ben Umberger
Default Fan Belt Speed (pulley ratios)
Greetings,
I am working on a 29 and and when it came to me it had a 1/2" belt which sits lower in the pulleys.
When I replaced it with a 5/8" (standard Model A) it rubs the radiator inlet hose so I put back a 1/2" belt.
The question is can anyone tell me since the belt sits lower in all of the pulleys is the fan speed unchanged, faster or slower?
I do have an over heating problem which I think is actually a new (used) radiator but the fan speed question bugs me.
Thanks
Ben Umberger is offline   Reply With Quote
Old 03-25-2017, 10:28 PM   #2
Brian in Wheeling
Brian in Wheeling's Avatar
Default Re: Fan Belt Speed (pulley ratios)
I put a smaller pulley on the crank and a larger pulley on the pump... custom made, slows down the water pump....but make sure your radiator is good and clean first.
Brian W.
Brian in Wheeling is offline   Reply With Quote
Old 03-25-2017, 10:53 PM   #3
Special Coupe Frank
Special Coupe Frank's Avatar
If the belt is riding equally "lower" in the groove of both pulleys, then there should be no change in fan / pump speed. The effective diameters of both pulleys relative to each other is still the same.
If the belt is touching only on the inside, flat surface of the belt, and not the Vee sides, it might slip on the generator pulley, and if you have to crank the belt tension up to prevent slippage, that could cause accelerated wear on the water pump and generator bearings.
Then again, it might be fine.
Special Coupe Frank is offline   Reply With Quote
Old 03-25-2017, 11:03 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
The fan with the correct belt turns at 1 1/2 times the crankshaft speed, so lowering the belt in each pulley the same amount (lets say 1/4") would increase the fan speed very slightly, but it would be so little that it wouldn't matter. Someone else can do the math.
Old 03-25-2017, 11:06 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
I still wonder why the belt hits the inlet.
With a good radiator and clean block, the A does not require a water pump.
Old 03-25-2017, 11:13 PM   #6
Tom Wesenberg
I've heard of the fan hitting the radiator inlet on a repro, because the neck angles down too much, but I never heard of the belt hitting.
Old 03-25-2017, 11:45 PM   #7
Synchro909
Synchro909's Avatar
I think the OP is talking of the belt rubbing the inlet right at the radiator outlet. I had that one time and even fitted a smooth metal plate (piece of soft drink can) under the hose clamp to prevent the belt rubbing the hose through while on tour. The final cure was to put on a shorter belt and move the generator/alternator in closer to the motor. That changed the angle of the belt as it came off the crankshaft pulley enough that it missed the hose.
To the OP, I think any change to the fan speed would be so minor that you can forget it and it is not the cause of your overheating.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-26-2017, 06:14 AM   #8
George Miller
George Miller's Avatar
Originally Posted by Ben Umberger View Post
Greetings,
Thanks
Fan speed is not your problem. You should be able to drive down the road with out a fan with no problem. You need the fan for stop and go traffic, or idling.
George Miller is offline   Reply With Quote
Old 03-26-2017, 11:51 AM   #9
Bob C
Greetings,
Thanks
It must be rubbing the radiator outlet hose, there is no way it could
rub the inlet hose. Have you tried a shorter belt?
Bob
Old 03-26-2017, 12:17 PM   #10
CarlG
CarlG's Avatar
Brian W.
Bill Stipe makes a set of pulleys like this.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-26-2017, 06:57 PM   #11
Ben Umberger
My first thought was that the new (used) radiators outlet neck was on an incorrect angle, it is quite difficult to measure as there is no dependable reference surface from which to measure and compare the old one with the new (especially when in the car) one but it doesn't seem to be the problem.
I then realized that if I had the radiator top to far forward (hadn't even tried to put the hood on yet) that would kick up the Inlet. That didn't solve the problem. Then I realized that the rubber pads that the radiator sat on were thicker than they need to be so I replaced them with something only 1/16" thick. Still rubbing. Only changing the belt got me clearance.
By the way, the belt is as short as it can be to actually get it onto all 3 pulleys.
Also note that the new radiator over heats at long stop signs, further investigation shows that this is why the previous owner sold the thing in the first place (sold directly to the cars owner)
Also note the radiator had been sent to a shop for cleaning, painting and general inspection. Looks like their judgement wasn't on target.
It has been resolved that a new radiator will be purchased, we'll see how it fits.
Thanks
Ben
Old 03-26-2017, 07:31 PM   #12
Tom Wesenberg
The radiator bottom outlet for 28-9 should point slightly away from the engine, and very slightly downward as I recall. I have an original I can check for the downward part, but it should angle outward for sure.
Old 03-27-2017, 05:33 AM   #13
Tom Wesenberg
Here you can see the original radiator outlet and pipe going to the block.
Does your radiator outlet and pipe have the same angles?
Old 03-27-2017, 05:41 AM   #14
Synchro909
Synchro909's Avatar
What am I missing? Why is there a hose bypassing the engine? I can see why there might be a hose coming from the inlet at the side of the block like that to a point towards the rear of the engine but bypassing it altogether?
Old 03-27-2017, 05:54 AM   #15
Tom Wesenberg
I have a thermostat and this helps for quick even heating of the block. It's temporary and will be the inlet and outlet for my heater core.
Old 03-27-2017, 06:30 AM   #16
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
Tom, where IS the thermostat? If it's in the upper radiator hose, it's after the point where the bypass hose enters the hose neck on the front of the engine. If that's the case, very little water will flow through the bypass hose until the thermostat opens, and I question the "quick even heating of the block".
Bill
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 03-27-2017, 06:38 AM   #17
Tom Wesenberg
Bill
? You want the heater hose to be before the thermostat, which is in my top hose right next to the cast outlet. This is the only way you get good circulating pressure.
Why do you question the quick even heating of the block? I have coolant circulation at all times.
Old 03-27-2017, 07:13 AM   #18
1crosscut
1crosscut's Avatar
Ben - Are you sure that your timing is set correctly? Retarded timing will cause overheating.
A club member ordered a new radiator last year because of overheating. I reset his timing before he installed it. Overheating problem solved. He sent the radiator back.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-27-2017, 07:51 AM   #19
Yes. I re-read your original post and see that the "quick even heating of the block" is by function of the thermostat. I confused the hose being there as the tool for that. Wrong! My bad. The hose in the picture is just to cover up the open holes in the water system, not to serve some sort of purpose.
Bill Lee
