Old 07-27-2017, 10:23 AM   #1
jchochole
jchochole's Avatar
Default How to remove broken glass?
Hey Guys,
I have 1930 Deluxe Roadster with cracks in the glass, my local glass place can't figure out how to remove the glass? Any ideas? No screws that I can see anywhere.
Thanks,
Jim
"Whether you think you can, or think you can't- you're right." H. Ford
jchochole is offline   Reply With Quote
Old 07-27-2017, 10:36 AM   #2
J Franklin
J Franklin's Avatar
Default Re: How to remove broken glass?
Look closer there has to be some fasteners holding it together, they didn't form the frame around the glass.
Old 07-27-2017, 10:36 AM   #3
Phred
Phred's Avatar
The 2 sides and bottom are one piece and the top rail is a separate piece.
The threaded stud in the second photo also holds the top rail in place.
Double nut the stud on each side, remove the studs, and then you can drive off the upper rail to remove the glass.
Hope this helps.
Phred, Herb's Glass, Elgin IL
Phred is offline   Reply With Quote
Old 07-27-2017, 11:26 AM   #4
wrndln
Phred is correct, there are no screws holding the top to the sides of the frame like 28/29 and closed vehicle windshield frames, just the special pivot bolt. These bolts can be tough to remove after years of rusting to the frame. You don't want to break them off. Heat is usually the best way to break the bolt loose.
Rusty Nelson
