Old 01-26-2017, 03:25 PM   #1
Dads41SuperDeluxe
Dads41SuperDeluxe's Avatar
Default Oversized O.D. Main Bearings
Can anyone confirm what I am hearing from my machinist? He was installing new main bearings in my '41 Sedan Coupe and says that the block and bearing caps have been line-bored 0.015 over original and requires the bearing to be 0.015 larger outside diameter. My existing bearings fit, but replacement bearings are loose. He says that during the war, in order to save a block that had spun a bearing, they would line bore the block/bearing caps and install a bearing that had a larger diameter.
So, for my '41 Sedan Coupe:
1) Is this true?
2) If it is true, does anybody have replacement bearings with larger OD?
Thanks
Len
Dads41SuperDeluxe is offline   Reply With Quote
Old 01-26-2017, 03:59 PM   #2
40 Deluxe
Default Re: Oversized O.D. Main Bearings
Are there markings on your old bearings to indicate oversize? There usually are, either the oversize dimension or a special part number.
Old 01-26-2017, 04:11 PM   #3
rotorwrench
rotorwrench's Avatar
Main caps are generally cut down a bit on the cap parting surfaces utilizing a special fixture in a lathe. The amount removed is generally small but it allows the bores to be re-centered & sized back to standard. If they did do it in the past, there may have been some oversize Id bearings at one time but I would doubt they be easy to locate now. I'll never say never on things like this but it might be easier to find another block. It won't hurt to look around a while though. You never know what is still lurking around out there in old parts piles.
Old 01-26-2017, 04:20 PM   #4
Dads41SuperDeluxe
There was not a part number and any indication that the OD was different. We ordered bearings assuming they would slip right in. Problem is they slip in to easily.
Where can I get a block?
Old 01-26-2017, 04:30 PM   #5
jehagado
1) Is this true?
Yes
I bet they are to find, if anyone knows it is here.
Ask the shop if they can mill the caps and line bore to standard.
jehagado is offline   Reply With Quote
Old 01-26-2017, 04:45 PM   #6
flatrod
flatrod's Avatar
Line boring it back to standard would get you into a gear back lash problem. Would need to find under size cam gear then. Best to find another block if bearings can't be found.
flatrod is offline   Reply With Quote
Old 01-26-2017, 04:51 PM   #7
rotorwrench
Check with barnfind08 in this forum. He had some of those a while back according to this link. https://www.fordbarn.com/forum/showthread.php?t=186941
Old 01-26-2017, 05:08 PM   #8
flatheadmurre
flatheadmurre's Avatar
Is it a 59ERP block ?
They are .015 oversize from start...should have ERP stamped into the block.
Old 01-26-2017, 05:26 PM   #9
Dads41SuperDeluxe
I'll check if its stamped ERP tomorrow when I go back to his shop.
Thanks
Old 01-26-2017, 09:32 PM   #10
Brian
Brian's Avatar
What size is the crank journals?
Rear main .015 oversize/std 81A 6331 H
.015/ ,010 81A 6331 K
.015/.020 81A 6331 U
.015/.030 81A 6331 V
All the above bearings have length between flanges .010 narrower than stock [stock is 2.095/2.097]
front and centre main bearings with .015 oversize o/d
.020 under crank 81A 6333 P
.030 under crank 81A 6333 Q
Sorry, have no other info on other sizes
Old 01-26-2017, 10:32 PM   #11
Dads41SuperDeluxe
Good information. I'm taking it to the machine shop. Thanks
Old 01-26-2017, 10:51 PM   #12
tony starr
tony starr's Avatar
Is this the same engine that had a rebuild plate? Pity it wasn't legible, it might of had this detail.
-tony.
tony-starr.com
tony starr is offline   Reply With Quote
Old 01-27-2017, 09:48 AM   #13
Dads41SuperDeluxe
Tony Good catch - Yep same engine
Old 01-27-2017, 01:51 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Contact Fred Wilner, otherwise known on this forum as "barnfind08". He had the bearings you're looking for as of January 2016. Fred is the "go to" guy for hard-to-find NOS Ford parts. Click the link below to send a PM directly to barnfind08. DD
https://www.fordbarn.com/forum/privat...do=newpm&u=104
Click Links Below __
T5 W/TORQUE TUBE
Old 01-27-2017, 02:12 PM   #15
Dads41SuperDeluxe
ERP is stamped on the block. Ouch. Machine guy didn't know.
Thanks V8 for the contact information. Sounds promising.
Old 02-28-2017, 11:15 PM   #16
Dads41SuperDeluxe
OK - Barns didn't have any available. Does anybody have other leads? My machine guy is getting pushy.
Old 03-01-2017, 12:29 AM   #17
Flathead
Flathead's Avatar
Those ERP blocks are still lurking out there. I got bit myself maybe 30 years ago and I never forgot about it. I did finally find some bearings but it took a while, and most people didn't know what I was talking about.
Flathead is offline   Reply With Quote
Old 03-01-2017, 08:10 AM   #18
Chuck Kuntz
I have some of those bearings. Do you know what oversize you need?
Chuck Kuntz is offline   Reply With Quote
Old 03-01-2017, 08:32 AM   #19
richard crow
BEARINGS CALL GOTHAM AUTO PARTS you will speak to james formley of job lot a great man to deal with he can help 718 878 3699 tell him richard of gas light garage sent you
richard crow is offline   Reply With Quote
Old 03-01-2017, 11:52 AM   #20
Dads41SuperDeluxe
Thanks Richard - no luck with james, but nice guy. Flathead - I'm finding the same thing. My rebuilder is talking about shimming. Anyone tried that?
I'm trying Chuck now
