Old 07-02-2017, 07:12 PM   #1
Nick in Fayetteville
Default 16 inch wheels
With a high speed rear end (3:54) in my Tudor, how would it effect it to replace the 19" wheels with 16". Thanks....
Nick in Fayetteville is offline   Reply With Quote
Old 07-02-2017, 07:20 PM   #2
Slowplane
Slowplane's Avatar
Default Re: 16 inch wheels
It will depend on the diameter of the tires. The wheel itself is immaterial.
______________
Nothing Short of Right is Right
Slowplane is offline   Reply With Quote
Old 07-02-2017, 08:02 PM   #3
PC/SR
Probably not much change. The 16" tires are about the same diameter as the 19" tires. As I recall they are both about 29-30 inches.
PC/SR is offline   Reply With Quote
Old 07-02-2017, 08:14 PM   #4
Synchro909
Synchro909's Avatar
From my post in a recent thread:
5.00X19 tyres give a rolling diameter of 29"
6.00X16 tyres give a rolling diameter of 28"
As was said above, it depends on the size of the tyre too but with those figures, Going to a 3.54 diff raises your ratio 6.35% and you will lower the ratio by 3.45% with the smaller wheels. Pretty much back to where you stated!
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 07-02-2017, 09:19 PM   #5
waxhead
waxhead's Avatar
I run 650x16 Firestone bias ply tyres on my 16 inch wire wheels. These give an overall diameter of 29".
However, the 650x16 tyres are for a recommended wheel width of 4.5 to 5.0 inches. The 1935 ford 16 inch wire wheels are 4 inches wide, but lots of people run the 650x16 tyres on these wheels without a problem, myself included.
waxhead is offline   Reply With Quote
Old 07-02-2017, 10:46 PM   #6
Synchro909
Synchro909's Avatar
When recommendations like those are made, they are usually super conservative so they should work OK. The only problem I can foresee using the narrower rim is in case of collision and insurance companies get involved.
Old 07-02-2017, 11:22 PM   #7
waxhead
waxhead's Avatar
Very true, that's why I wanted to point out the recommendation on the wheel width.
Old 07-02-2017, 11:40 PM   #8
31Abone
31Abone's Avatar
What about the look factory ?? 16 wheels look like crap x 1000
31Abone is offline   Reply With Quote
Old 07-03-2017, 12:23 AM   #9
Chris Haynes
Chris Haynes's Avatar
They look just fine on my car. :-)
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-03-2017, 12:31 AM   #10
Charlie Stephens
Beauty is in the eye of the beholder. After saying that I am running stock wheels. The good thing is that they are easy to change.
Charlie Stephens
Old 07-03-2017, 07:17 AM   #11
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Yes I know what you mean Charlie about easy to change.Don't use the 16" wheels, they are a nightmare to find the mounting studs and screw on the acorn nuts because you can't see the studs when mounting, the 19 and 21" wheels are easy to mount because you can see the studs. I had the 17" wheels on my roadster(same problem) but went back to the Model A 19".
Barry B./ Ma. is offline   Reply With Quote
Old 07-03-2017, 07:54 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
1932 Ford 18" wheels are prettier!
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 07-03-2017, 07:55 AM   #13
V4F
V4F's Avatar
I have used 16" for like 10 yrs. I lock my brake so studs are ez to find .
V4f
V4F is offline   Reply With Quote
Old 07-03-2017, 08:14 AM   #14
Slowplane
Slowplane's Avatar
______________
Old 07-03-2017, 07:26 PM   #15
Thanks Guys...I'm considering...Local guys tell me 16 inch is the only way to go for long distance touring. 19's for local runs and around town. I just finished a 485 mile tour with my 19's. I find that the car "floats" on roads that have had a lot of wear. I thought that the 16's might smooth out the ride. I know it is in the roads, there is nothing wrong with my car.
Old 07-03-2017, 07:40 PM   #16
Synchro909
Synchro909's Avatar
I've done many thousands of miles touring and I know what you are saying but I don't think it is the size of the wheel that is important. On one trip, I fitted 5.25X21 tyres to the rear of my '29. The difference was amazing compared to the 4.5s. Another fellow in our club has fitted larger tyres to his 19" rims (5.50, I think) and he says the same. Another difference between 19" and 16"is one is a conventional bias ply tyres while the other (16") is likely a radial. Even if the 16" is bias ply, it will have more rubber on the road and drive better. I am also told that the 19" radials that are available transform the car and will make it like a modern car to steer. That might be worth your time to check out.
Just a suggestion.
Old 07-03-2017, 11:27 PM   #17
Railcarmover
Well thats it,Im tossing these in the scrap pile...all the wires are bent anyway..besides they are some aftermarket crap
Railcarmover is offline   Reply With Quote
Old 07-03-2017, 11:43 PM   #18
RichardW
Railcarmover, Let me know where your scrap pile is.
RichardW is offline   Reply With Quote
Old 07-03-2017, 11:49 PM   #19
Railcarmover
yeah I Dunno,they are made by Kelly Haze or some odd ball outfit like that..hell,might as well run them on the '29,they fit and it cant make it look any more like a shriner clown car than it already does..
Old 07-04-2017, 12:33 AM   #20
CarlG
CarlG's Avatar
550R19 Radials by Coker. Best of both worlds.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
