Old 02-18-2017, 06:39 PM   #1
hotrodA
hotrodA's Avatar
Default 38-41 Pickup body to frame bolts??
I understand that the OE type cab to frame bolts (as furnished by Roy N) have a small spring that is used to allow the cab to move around to cushion the cab and occupants.
Are these really necessary on a truck that will never be off smooth pavement?
How about some thin rubber cushions or thicker webbing between the cab and frame and bolt it directly?
Thanks!
hotrodA is offline   Reply With Quote
Old 02-18-2017, 06:47 PM   #2
alanwoodieman
Default Re: 38-41 Pickup body to frame bolts??
there is a pad also. the bolt goes thru the cab mount thru a rubber cushion then thru the frame and under the frame the spring goes on the bolt, which has a cotter key hole and a crown nut. this spring allows the frame to flex with out flexing the cab mount.
Old 02-18-2017, 10:22 PM   #3
Tinker
Tinker's Avatar
Yes they are a good thing. Might find a valve spring will work just fine.
Frame welting is fairly cheap.
Roy is a great guy.
Old 02-19-2017, 10:04 AM   #4
hotrodA
hotrodA's Avatar
Thanks for the responses.
How about radiator mounting springs?
Old 02-19-2017, 02:10 PM   #5
TomT/Williamsburg
TomT/Williamsburg's Avatar
Wow - never knew about cab springs for a 1/2 ton. I've always got the 2-3 I've owned mounted on the wood and bolted them down. Only thing separating the wood from the frame was frame webbing. Thanks for the info
TomT/Williamsburg is offline   Reply With Quote
Old 02-19-2017, 04:48 PM   #6
V12Bill
V12Bill's Avatar
Mine has springs on the front 2 and the rear 2 bolts. I used a valve spring on one that was missing.
V12Bill is offline   Reply With Quote
