https://youtu.be/mAwboVk3r4A
See the bus info at the 7:36 mark. Was the engine in this bus a 85hp flathead or did they use the 337 flathead? |
I THINK the 337 didn't come into use until about '49-ish. DD
V8Coopman is right. The 337 Lincolns didn't come out till 1949. I think the last year used was 1951 in the car and 1952 in the truck.
On a 1941 it could be and 85 HP 221 CID engine as standard but could also have a 95 HP 239 CID engine as an option.
The 1944 rear engine bus began using a high volume fuel pump that became known as the "Bus pump" used by racers in the late '40s. I suspect vapor lock was a problem with the rear engine location. |
