Old 02-07-2017, 04:14 PM   #1
steve hackel
steve hackel's Avatar
Default Can anyone "re-ball" a 1934 pitman arm????
Does anyone know of a place that will install a new steering ball on my 1934
pitman arm? I have had ZERO success finding someone that can do the job and do it correctly. This is the last piece of the steering (besides the box) that I need to finish so I can then drive the car again. Thanks in advance!
steve hackel is offline   Reply With Quote
Old 02-07-2017, 04:30 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Can anyone "re-ball" a 1934 pitman arm????
There is a ebay seller that sells the pitman with new ball installed and will give you a core charge refund on your old.
Old 02-07-2017, 04:34 PM   #3
Terry,OH
Terry,OH's Avatar
All Ford Parts: 800-532-1932 They rebuild them 175.00 minus your core 100.00 I have no idea how they are attaching the new ball, as a guess brazing. See ebay
172499516735
Old 02-07-2017, 05:40 PM   #4
my4dv8
Are later pitman arms the same spline and length?
If so they won't care if they go from cross steer to side steer, and fit a bolt in ball.
my4dv8 is offline   Reply With Quote
Old 02-07-2017, 06:20 PM   #5
Jason in TX
Jason in TX's Avatar
Here is that ebay listing
http://www.ebay.com/itm/1933-34-Ford...-/172499516735
I don't know how this is staying on...
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 02-07-2017, 07:19 PM   #6
cas3
a friend of mine welds them up and grinds them by hand using the hole in a washer to check roundness......he has more time and patience than me !
Old 02-07-2017, 08:43 PM   #7
whizzernick
whizzernick's Avatar
i have several good ones
nick 510-889-1933
whizzernick is offline   Reply With Quote
Old 02-07-2017, 09:43 PM   #8
steve hackel
Thanks for all of the information; I will start with the guy on E-bal and go from there. Thanks Nick, I'll call you tomorrow - it's too late tonight.
Thanks to everyone, Steve
Oops - does anyone know if the later style pitman arms from the 40s etc would fit the splines on the 34 steering box cross shaft? I could easily get one of the replacement screw in studs and adapt it, or even go to a tie rod end style drag link and make everything new.
Any help on this question?????
Old 02-07-2017, 09:50 PM   #9
skidmarks
skidmarks's Avatar
Splines the same. You might have to reshape it a little depending on the one you use
skidmarks is offline   Reply With Quote
Old 02-08-2017, 08:06 AM   #10
woodiewagon46
Steve there are a couple of ways that this job is done. The first is to remove the entire old ball and drill a hole in the arm. Then they insert a ball that has a stud attached and then weld it up. The second way is the preferred way. The pitman arm is set up in a milling machine and the ball is removed but a "stud" is left intact on the pitman arm. A stainless steel ball is then pressed onto the stud and the end TIG welded and rounded off.
woodiewagon46 is offline   Reply With Quote
Old 02-08-2017, 08:07 AM   #11
Tim Ayers
Not sure if you saw this. For sale in the swap section. $20 for the arm and drag link.
https://www.fordbarn.com/forum/showthread.php?t=214511
Old 02-08-2017, 12:52 PM   #12
Chris
Chris's Avatar
I used a 37-40 arm on my 34. They have 4 large grooves on the sector, and the pitman arm has 4 larger splines. I could not get mine to clock right, so I used a very small triangular shaped file, and
"V'd" the large groves and now it will fit the sector at any degree. Only took a little time to file.
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 02-08-2017, 01:11 PM   #13
JSeery
JSeery's Avatar
Originally Posted by Chris View Post
I used a very small triangular shaped file, and "V'd" the large groves and now it will fit the sector at any degree.
A common mod I have used several times as well.
Old 02-08-2017, 03:53 PM   #14
Jason in TX
Yep. Same here.
Old 02-08-2017, 05:31 PM   #15
PeteVS
PeteVS's Avatar
If you file out the "fat" splines (per post #12), you want to have the pitman arm straight down when the steering wheel is right at the middle between full left and full right. Then, you want your drag link to be sized to put the wheels straight ahead at this point. If you use the "tie rod end" type of drag link, you should be able to get the steering wheel nicely centered when you're driving straight.
Old 02-09-2017, 03:22 PM   #16
V8COOPMAN
V8COOPMAN's Avatar
Click Links Below __
T5 W/TORQUE TUBE
