Old 02-02-2017, 09:19 AM   #1
bwaii64
Default Grinning and "bearing" it
I want an opinion. Sure I'll get many. Took main bearing cap off and found this. This isn't a cross country or daily driver car and runs fine. This is the front and is cast. I'm in a foreign country (Brazil) and getting a new one is a very major ordeal.
Should I...
1) leave the **loose** piece in and bolt it up and run it until it worsens.
2) REMOVE the piece and bolt it up and run it until it worsens.
3) stop the presses and re-do everything 'cuz she's guna blow!
4) Try to fill it with solder (white or yellow) so I don't loose the oil if it all breaks loose.
Save
Save
bwaii64 is offline   Reply With Quote
Old 02-02-2017, 09:42 AM   #2
Dave in MN
Dave in MN's Avatar
Default Re: Grinning and "bearing" it
Given that the car is for occasional use, I would go with your option #1, making sure the clearance is correct. I see the right side of the cap in the picture had a shim...remove a lamination as required. Use any method you are comfortable with to make sure the oil clearance is about .0015". You will likely get years of service from the engine if you keep the speed down and the oil clearances proper. Leave the loose piec in place.
Good Day!
Dave in MN is offline   Reply With Quote
Old 02-02-2017, 09:54 AM   #3
CWPASADENA
CWPASADENA's Avatar
Good Day!
I agree.
It is not perfect but it should give you a lot of service for the type of driving you are doing.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-02-2017, 10:07 AM   #4
harleynut
harleynut's Avatar
I agree with #1,#2,#3 what do you have to lose at this point
harleynut is offline   Reply With Quote
Old 02-02-2017, 10:31 AM   #5
JonC
I don't know if you need more opinions or not, why did you take it apart? Nothing else to do, or was it making noise. but other than that I agree too.
JonC is offline   Reply With Quote
Old 02-02-2017, 11:39 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I also agree with Dave and the others. The front bearing has the easiest job, and what you have will last until the engine needs more work.
Old 02-02-2017, 11:54 AM   #7
jim galli
jim galli's Avatar
That's why I don't take mine apart. Ignorance is bliss.
He is no fool who gives what he cannot keep, to gain what he cannot lose... Jim Elliott, 1949
http://tonopahpictures.0catch.com
jim galli is offline   Reply With Quote
Old 02-02-2017, 11:54 AM   #8
bwaii64
Should I leave the loose piece in there?
Just thought of this, what if I try to fill it with solder. The area is badly cracked and I'm afraid if it comes loose I'll lose lubrication.
Old 02-02-2017, 11:57 AM   #9
bwaii64
Trying to take out axial play and reduce rear oil leak.
Old 02-02-2017, 11:59 AM   #10
bwaii64
haven't seen evidence of shims. Must just glare from my 5 pixel camera.
Old 02-02-2017, 12:04 PM   #11
bwaii64
and sometimes ignorance gives blisters.
P.S. Elliot's one of my "heroes"
Old 02-02-2017, 07:05 PM   #12
colin1928
colin1928's Avatar
Do not leave the loose part in there it will not help and only move where it is not wanted
I would rebuild it or find a better cap
colin1928 is offline   Reply With Quote
Old 02-03-2017, 03:02 PM   #13
hardtimes
hardtimes's Avatar
'gives blisters'...good one ! Don't know where this 'saying' originated , but is anything but bliss. Just had someone die because he strongly adhered to this saying (regarding doctor visits). Died of cancer and didn't know that he had it till tooo late to treat...your call .
bwaii64
sending you PM
Old 02-03-2017, 03:33 PM   #14
jim galli
jim galli's Avatar
Model A Fords are neither religion or life and death. People on forums need this reminder sometimes. Now, ignoring the brakes too long, perhaps, could be death defying.
Old 02-03-2017, 03:58 PM   #15
Tom Wesenberg
I hope you don't get struck by lightning.
Old 02-03-2017, 11:04 PM   #16
Mike V. Florida
Mike V. Florida's Avatar
