I have an original cut-out cover that is perfect, except for a few small pits in places. I used some plumbing solder that I had available, flux, and a butane torch (heating from inside the cover) to melt some solder into place. This worked until I went to sand it smooth after cooling. The solder would tear away in pieces. Is this a function of the type of solder, or am I missing something else? This would seem to be a no-brainer (it says here).
I also want to fill some pits in an instrument panel that I plan to plate. I'm not sure that the copper plating stage of the process will be sufficient to hide the pits though. Gordon |
Proper tinning on a properly prepared surface should keep the lead from flaking away on the cutout . For your dash panel, lead sold will not take a plating like the parent metal. Instead use silver solder on a properly prepared surface and it will plate over beautifully matching the rest.
Thanks for the response. Minor questions for the purist:
Are all silver solders alike, or is a Home Depot brand adequate? Any trick to the preparation; flux just before heating? Any other preparations to the metal that you recommend? Do you use a high heat to melt the solder (e.g., propane), or would a butane torch suffice? Is it necessary to spread the melted solder with any kind of paddle, or would a wooden popsicle stick suffice? Lastly, sand smooth with a fine file, or 400-grit sandpaper? Thanks. Gordon |
For filling the cutout cover I would use a good heavy duty soldering gun, like a WEN 250, or a heavy duty soldering iron. Sandblast the cover with Black Beauty grit to get all the rust out of the pit. Use a good rosin flux and 60/40 electrical solder.
Instrument panels with pits can be very labor intensive, as I've done one. I won't do another, but instead buy a better panel, or a restored original panel. |
Get one of Don Turley's restored original panels. They are probably the best around. Mine looked like "Brand New" when I got it.
#7 | |
![]() Quote:
coal slag glass abrasive iron / copper slag and which grade ? |
I always buy the coal slag from Menards. Don't know the grade, but think they only sell the one grade.
Thanks for the posts. I plan on having the cover plated, otherwise I would use JB Weld and a razor blade to eliminate the pits.
My instrument panel is in excellent shape, except for the few pits. Hence, I like the challenge of preparing it for plating myself. I guess that I will experiment with some silver solder. |
#10 | |
![]() Quote:
Black Beauty comes in three grades fine-med. etc. I have have excellent results using tinning butter from Eastwoods when using lead on my projects. The paste is grey in color but when heated turns to a chrome like finish when using a damp rag wipe the area, it will show you where the adhesion is and body solder will stick to it very well. It has it's own flux mixed in.
Any rust left in the pits will cause adhesion problems with the solder.... it won't "flow-over" the void, but instead will flow around it, leaving a little pin-hole.
#13 |
Hey, Brent! It's been a while. Convey my best to your dad, by all means.
For cad plating I've used Delta Specialty Coatings on Heiser here in Houston. They acquired Electro Specialty Coatings, whom I had been using, back in 2005. They have a minimum charge for plating ($100?), which means some pooling in most cases. I will have Bright Metals of the Heights do the instrument panel. They apply a brushed nickel finish, which is an excellent replica of the original Butler finish. (Bryan Perkins has two of my oval instrument panels in such a finish.) As to the plating posts, thanks for the suggestions. I will try some flux and electrical solder and see how it flows. I should get a tentative reading from the plating shop tomorrow as to how successful the copper layer might be in hiding the small pits. |
