Old 01-05-2017, 05:40 PM   #1
Rob Rose
Default 31 Tudor Starter Quit Working
I am a newbie, I have had my car for 3 months. Today I adjusted the timing and then went to start it and left the cable that plugs into the distributor disconnected and cranked the motor and then the starter just quit working. I have not had an issue with the starter. I plugged the cable into the distributor, and the battery is fully charged, but nothing happens when I press the starter button. My car is a intact original with 22,000 miles on it. Any guidance is appreciated!
Rob Rose is offline   Reply With Quote
Old 01-05-2017, 05:43 PM   #2
John Stone
John Stone's Avatar
Default Re: 31 Tudor Starter Quit Working
put your tranny in high and rock the car back and forth. Sounds like a locked starter.
John Stone is offline   Reply With Quote
Old 01-05-2017, 05:44 PM   #3
Rob Rose
did that, nothing.
Old 01-05-2017, 05:54 PM   #4
John Stone
John Stone's Avatar
Did the engine turn over OK? If it did, the starter switch may need some attention.
Old 01-05-2017, 05:56 PM   #5
Rob Rose
it turned over but didn't start, then the starter quit
Old 01-05-2017, 06:01 PM   #6
John Stone
John Stone's Avatar
Let me get this straight. If you walked out to the car right now, put it in high and pushed it a little the engine would turn over?
If so, then I would check the switch if all cables are tight and you have a good ground.
Old 01-05-2017, 06:05 PM   #7
Rob Rose
Thats right the engine turns over in gear when I push it. I'll check the battery cables tomorrow but the lights are working fine. Don't know how to check the switch, maybe just order one?
Old 01-05-2017, 06:09 PM   #8
John Stone
John Stone's Avatar
You would have to unhook the ground cable, unscrew the starter rod, remove the nut holding the cable and wire that goes to the terminal box and then remove the 4 screws hold the switch in place. It ought to be obvious once you look at the inside.
Of course it could always be a dead spot in the starter armature.
Old 01-05-2017, 06:13 PM   #9
Rob Rose
Ok thanks!
Old 01-05-2017, 08:26 PM   #10
700rpm
700rpm's Avatar
Do the lights dim when you step on the starter?
Ray Horton, Portland, OR
Old 01-05-2017, 09:45 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
BINGO
A quick easy check that will help diagnose the problem. If the lights don't dim, it would be a problem in the starter switch. If they dim, then it would be inside the starter, if the battery is in good condition. That is unless the switch contact is shorting to the cover.
Old 01-06-2017, 02:11 PM   #12
Rob Rose
Thanks, the lights don't dim. I ordered a new switch. Hopefully thats it.
Old 01-06-2017, 02:33 PM   #13
daveymc29
daveymc29's Avatar
Try the hand crank starting. It may be a dead spot on the armature as suggested above. Or while you have the starter switch off, put the car in neutral, hand brake applied, touch the exposed copper disc on the top of the starter with the hot lead from the battery. Engine should turn over. Just some options.
daveymc29 is offline   Reply With Quote
Old 01-06-2017, 02:38 PM   #14
Tom Wesenberg
I agree, do these checks first before buying new parts. Although a spare switch is OK to have.
Old 01-06-2017, 03:52 PM   #15
Jacksonlll
Jacksonlll's Avatar
Take the switch apart. There is nothing to it.
Old 01-06-2017, 11:43 PM   #16
CWPASADENA
CWPASADENA's Avatar
[QUOTE=Rob Rose;I ordered a new switch. Hopefully thats it.[/QUOTE]
I agree with JACKSONIII
I would take the switch apart and it may just need to be cleaned.
Sometimes, a "new" part may not be nearly as good quality as the original.
The original starter switched are very good and usually do not cause many problems.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 01-06-2017, 11:54 PM   #17
Capt Quahog
Capt Quahog's Avatar
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Drove around often in Model A Ford cars for periods of time with a busted starter. Would park the thing on a slight grade, then let her roll and pop the clutch. It was usually broken bendix spring, bad switch or some standard situation. Great thing about an A Model Ford, it's usually pretty easy to get them started in a pinch.
I wouldn't be so paranoid if people weren't plotting against me all the time
Capt Quahog is offline   Reply With Quote
Old 01-07-2017, 12:32 AM   #18
eagle
eagle's Avatar
Put a voltmeter on the starter, using the + battery post as reference. If you have power to the starter switch, then check case of starter, should NOT be voltage there. Next pull off starter switch and touch battery cable directly to starter "nub". Use a voltmeter to verify power there. I would DEFINITELY fix the old starter switch rather than replace, if that proves to be the problem. Don't start throwing parts at the problem until you troubleshoot it down to the bad part.
Old 01-09-2017, 12:25 PM   #19
Rob Rose
Ok, I got the new switch and it does seem very simple-I haven't installed it yet, I am going to check and clean all connections including those in the old starter switch today, but I see that there is something that looks to me like a fuse marked 12V 30A. I unclipped it but I don't see if the back box opens to reveal a fuse inside. Could this be the problem? here is a pic of that.
Old 01-09-2017, 12:45 PM   #20
Bob C
That looks like a circuit breaker.
Bob
