Old 01-05-2017, 04:13 PM   #1
Mad Mac
Default Black plugs
Here are the spark plugs from my stock 29 Model A RPU. As they are very black and carboned-up, it must be running too rich - right? However I always close the GAV fully when driving. When idling, the motor stops "rolling" as soon as I rotate the GAV to the driving position, indicating that it is not running too rich. So what's going on here? Hope you can help.
Mac
Mad Mac is offline   Reply With Quote
Old 01-05-2017, 04:17 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Black plugs
Try a hotter range plug.
Old 01-05-2017, 04:24 PM   #3
Brentwood Bob
https://www.fordbarn.com/forum/showth...lug+heat+range
Do a thread search. The above is larry blumfield's list of spark plug heat ranges.
Brentwood Bob is offline   Reply With Quote
Old 01-05-2017, 04:38 PM   #4
Brian T
Brian T's Avatar
I dont see that changing plugs will fix your problem, get the carb fixed first, when the carb is set up properly and idle speed where it should be 500 - 600 rpm there should not be any influence from the GAV.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 01-05-2017, 04:39 PM   #5
C26Pinelake
i think your plugs are fine, it's your carburetor. Wayne
C26Pinelake is offline   Reply With Quote
Old 01-05-2017, 05:20 PM   #6
Mad Mac
So what is likely to be wrong with my carb?
Old 01-05-2017, 05:21 PM   #7
Synchro909
Synchro909's Avatar
Most of the jets available from vendors are not quite the right size. Do you have a set of flow tested jets in the carb? If not, a set might fix this. I'm sure others will chime in here too. Renners is a place to get the good jets.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-05-2017, 06:01 PM   #8
Brian T
Brian T's Avatar
Hello Mac.
I see you are not new to your truck, is this a problem that as just started?, there are many suggestions that can be given depending on which carburetor you have and your abilities to follow them, let us know what as been happening and go from there, several excellent sites for Zenith carburetors here on the Fordbarn.
http://www.modela.org
Old 01-06-2017, 01:21 AM   #9
Mad Mac
Originally Posted by Brian T View Post
Hello Mac.
No the problem has been occurring for a long time and I think it probably arises in the carb. I run a standard Zenith carb which has not been flow-tested so my next move will be to get it flow-tested. I have a friend here who flow-tests them, so I will talk to him.
Thanks for your help.
Mac
Old 01-06-2017, 09:08 AM   #10
Jacksonlll
Jacksonlll's Avatar
You did not say how often this occurs. Model A plugs foul and require cleaning. Very easy to do. Check them and when black and fuzzy, just clean them.
Old 01-06-2017, 09:49 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
Carburetor jets and an air filter will make the fuel air mixture too rich. Also the GAV needs to be 1/8 to 1/4 turn open when you setup the carburetor. Doing so gives the GAV a wider range of fuel-air mixture adjustment.
Another habit that carbons-up spark plugs is long periods of idling with a rich mixture.
Bob Bidonde
Old 01-06-2017, 09:58 AM   #12
rosenkranswa
rosenkranswa's Avatar
I have found a good carb cleaning, take it apart but don't remove the jets, especially given todays gasolines, seems to cure lots of problems which can be traced back to carb issues. I clean and gap the plugs once a year, clean the carb every two years, as part of my standard yearly maintenance along with a minor tuneup - points, timing, etc.
If that doesn't work, then start looking for other more insidious things.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'38 Columbia Girls bike (WWII)
'40 Elgin Boys bike (WWII)
'42 Super Deluxe Tudor
'42 Willys MB Jeep
'43 Willys MBT Trailer
'43 M3A4 Hand Cart
'43 Harley Davidson 42WLA with sidecar
rosenkranswa is offline   Reply With Quote
Old 01-06-2017, 10:04 AM   #13
Kurt in NJ
Kurt in NJ's Avatar
When everything is good-- mixture, spark, engine, the plugs do not get black, same 3X plugs, not cleaned in35 years except by driving --- got a set of black fowled ones out of the trash, put them in my car and after 20 miles look white and new( ran somewhat lean to cook off the black)
Old 01-06-2017, 10:42 AM   #14
wmws
I agree with Kurt. I never clean my plugs and they burn perfectly clean. And I use W14 plugs. Actually I wonder why I don't get better gas milage. I get about 17-18 MPG on the hi-way.
wmws is offline   Reply With Quote
Old 01-06-2017, 11:25 AM   #15
SeaSlugs
SeaSlugs's Avatar
your mpg could be any number of things: altitude, compression ( lack of), how hard you drive, what speed you drive, rear end ratio, always diving into the wind, tire psi, tire softness, alignment, dragging brakes, engine temp too cool, gav adjustment, carb tuned right, proper use of timing lever, etc
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-06-2017, 12:04 PM   #16
wmws
On my gas milage I drive mainly near sea level, compression is 55-57 on all cylinders, drive about 45-50 with a Mitchel overdrive, Rear is a 3.76, tires at 35 lbs, alignment right on, brakes don't drag. My engine temp may be a little cool with a 160 thermostat. i run 30* total advance. Carb is not flow tested but the plugs look spot on. Only 17-18 MPG.
Old 01-06-2017, 12:40 PM   #17
Ruth
It's the ethanol.
Old 01-06-2017, 01:12 PM   #18
Tom Wesenberg
Tom Wesenberg's Avatar
It does seem like you have everything right to get at least in the low 20's for mileage.
A 5.5 head should help some.
Old 01-06-2017, 04:43 PM   #19
Kurt in NJ
Kurt in NJ's Avatar
I used to get no better than 15-17, then I replaced the worn camshaft, put in valve seats to get the valves out of the hole (too many seat grindings), and put in a thermostat, on a long trip I averaged 23 at 55 plus over 1500 miles much of it at 65, before the work top speed was 52
Old 01-06-2017, 05:29 PM   #20
Chippy Minton
Originally Posted by Ruth View Post
It's the ethanol.
No it's not.
Chippy Minton is offline   Reply With Quote
