Old 12-29-2016, 09:37 PM   #1
motordr
Default 32 3 window door seal
Which way does the rubber door seal face? This is the seal between the door panel and door at the rocker panel. Does the lip face the door or inside? Thanks.
motordr is offline   Reply With Quote
Old 12-30-2016, 06:16 AM   #2
DavidG
DavidG's Avatar
Default Re: 32 3 window door seal
Since it is retained by the door trim panel clips, the only way it will fit properly is with the lip facing inward and adjacent to the very lower edge of the trim panel. You will likely find that the front edge of the door seal has to be trimmed somewhat given the configuration of the deluxe coupe's door opening.
Old 12-30-2016, 08:35 AM   #3
motordr
Thanks David, much appreciated. No problem to trim the seal, I will have to trim the panel slightly at the front corner to better conform to the door radius also.
Ted
