Old 12-02-2016, 09:45 PM   #1
Art Newland
Art Newland's Avatar
Default Just when I thought I understood A timing...
I was about to button-up my engine project when I thought I'd take a look at how the timing pin mark in the cover and the timing alignment marks on the crank and cam gear equate to the position of the piston/valves. While the timing marks are aligned, the #1 piston is at TDC and the exhaust valve is wide open. Is this correct?
File Type: jpg TDC exhaust valve open timing marks aligned.jpg (36.7 KB, 186 views)
Art Newland is offline   Reply With Quote
