Old 11-07-2016, 04:46 PM   #1
Fullraceflathead
Fullraceflathead's Avatar
Default Modifying Zenith for Air Balance
Does anyone have the step by step article or instructions on making the necessary modifications to make the carburetor Air pressure balanced?
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 11-07-2016, 04:48 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Modifying Zenith for Air Balance
If somebody with that Info sends it by PM, please include me.
I'd like to know too.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 11-07-2016, 04:49 PM   #3
J Franklin
J Franklin's Avatar
MAFCA magazine Restorer had that in one of their issues about 6 years ago if anybody has an index it could be found.
Old 11-07-2016, 05:02 PM   #4
Brian T
Brian T's Avatar
Do a search for Air balancing Zenith carburetors, using a larger air cleaning is a way around the problem.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 11-07-2016, 07:50 PM   #5
Benson
Chris Pelikan did a lot of research on the subject of the need for air balancing ... Here are his thoughts:
http://www.modela.org/filtering_air_into_carb.html
Old 11-07-2016, 08:14 PM   #6
tbirdtbird
it is quite simple and posted here before...Tom W just recently posted it about a month ago
'31 180A
tbirdtbird is offline   Reply With Quote
Old 11-07-2016, 08:26 PM   #7
Gary WA
Gary WA's Avatar
Nov/Dec 1994 pg 17. The Restorer
www.whidbeymodelaclub.com
Old 11-07-2016, 09:16 PM   #8
Synchro909
Synchro909's Avatar
Won't load.
Old 11-07-2016, 09:31 PM   #9
Gary WA
Gary WA's Avatar
Originally Posted by Synchro909 View Post
Won't load.
I just gave the reference on where to find it.
Old 11-07-2016, 10:19 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
Someone posted this picture a while back. You can see the vent hole is filled and the lower carb body and venturi are modified. I can only speculate that a 'port' is drilled in the body leading to the carb throat by the choke butterfly?
If I remember correctly this is how Renner's modifies the Zenith.
Old 11-07-2016, 10:42 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
If I wanted to add a balance tube, I'd buy a thin brass tube from the hobby shop or hardware store that fits tight into the air vent hole. It only needs to be about 3/4" long. Then slip a piece of tubing over the brass pipe and have it enter anywhere between the choke plate and air filer. This way you can have a balanced carb for an air filter without doing any cutting or drilling to the carb.
