Someone asked about putting their car on jackstands for storage. Which got me to thinking (scary), sooo change engine oil
check coolant fuel stabilizer mouse proof Please add to the list and/or comment! |
#2 | |
![]() Quote:
![]() PS. it will be in a heated garage. Last edited by Jemelton#; 10-29-2016 at 11:04 AM. Reason: added info |
Are you planning to store for the winter or 20+ years?
Charlie Stephens |
put a can of Seafoam in the gas tank. Wayne
mouse control definetly
From Experience:
1. Try dipping a Tee Shirt in oil until it is well oiled; and, hang it out on a clothes line. 2. After a few years, one can notice that the volatile petroleum products in the oil evaporated & the Tee Shirt is dry. 3. When this same effect happens in an engine, warmer humid air condenses on cooler engine parts and ferric oxide (rust) sets in. 4. Never a bad idea to start engine now & then ...... or as a minimum, rotate engine rapidly with hand crank with (4) plugs removed ..... oil pump "will" pump oil. 5. My Town Sedan sat in "heated" storage for 30 years .....with very little use during this period according to former owner ........ after removing pan, noticed the cam shaft had deep rust pits far beyond repair. 6. Storage: No cut & dry answer or fix because lots depends on: A. Humidity level in storage area; and, B. Length of storage between rotating engine and lubricating engine parts. 7. Again, FWIW, our U.S. Military stores rebuilt engines in a vacuum, in a metered fiberglass container, which can even stand open shipment over salt water seas plus years of non-harmful storage. 8. Dust accumulation during storage is detrimental to paint ..... dust accumulates moisture, moisture molecules penetrate paint film .... results in rust in some cases. 9. Rodents are a different subject .... depends "solely" on the person's desire to "effectively" control the storage area as opposed to trying to appeal to the rodents who desire to ruin a Model A. Just hope this helps anyone to decide. Last edited by H. L. Chauvin; 10-29-2016 at 12:38 PM. Reason: typo |
Remove the battery!
Don't forget to plug exhaust and carb holes..this falls under mouse proof but often to some that means just lay out traps.
_________________________________________ 1931 Ford Model A Tudor 1930 Ford Model A Deluxe Roadster 1930 Ford Original Rolling Chassis- Restoring |
Do not put your Model A into storage for the winter. Drive it every chance you can. Storage causes deterioration you cannot see.
Bob Bidonde |
Remove the battery or just disconnect it?
Make sure nobody is in your Model A when you store it & lock everything up.
Very important !!! |
#13 |
#14 |
#15 |
I always run the carb dry of gas.
#16 |
That engine with the two freeze cracks that I've been fixing up from the deer hauler looks like it won't get finished before the snow falls, so two days ago I used my syphon sprayer to spray engine oil on the interior of the bottom end, then used a few bolts to install the engine pan. This will stay outside covered up with plastic. I'll let you know in the spring how it survived, but I predict no rust.
#17 |
Tom,
Use common sense and avoid driving when the roads are salty. That leaves a lot of fall and winter days when it is fun to drive a Model A. So I stick to my recommendation of not storing any Model A.
Bob Bidonde |
#18 |
Tape a note to the windshield describing what you've done to the car, because you may not be the next person to start it!
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
#19 | |
![]() Quote:
Its not the driving on snow with salt mixed in, its the melted snow and mostly salty spray that gets in every little crack and destroys cars. Unless you own your own carwash and wash it top to bottom with a pressure washer and every crevace on the underside and body panel seam after every drive its much better to just park it and wait till after the 2nd heavy rain in the spring. Then you get to play the "dodge the landmines" game with potholes in the roads. ![]()
#20 | |
![]() Quote:
I did drive my car a couple times last winter but it was always after the melting and a couple rains to clean the roads....if I lived in NE Ohio or western NY I would park her for the winter for sure.
1930 Deluxe Coupe "Sister" |
