Old 10-03-2016, 01:44 PM   #1
Walt Ebie
Walt Ebie's Avatar
Default Installing a Temp probe
I'm about to embark on installing a temp probe pipe in my upper hose and would like to hear from anyone who's done it as to the best way to go about it. That is, first, remove the upper hose. But after that, did you measure and cut the hose and put the probe pipe in it and then put it on the rad and block as one piece? Or did you put it on, a piece at a time from the top down or bottom up? There must be one way that works easier than another and, if there is, I'd like to hear about it.
Walt Ebie is offline   Reply With Quote
Old 10-03-2016, 04:32 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Installing a Temp probe
"measure and cut the hose and put the probe pipe in it and then put it on the rad and block as one piece?"
There is really no single correct answer to this, but this is what I did.
You want the finished assembly of hoses and probe pipe to be the same length as your original upper hose, so measure the upper hose before you cut it.
Jim Cannon
"Spread the Joy! Have a Model A day!"
Old 10-03-2016, 05:08 PM   #3
Brianfrench65
Brianfrench65's Avatar
I put a new neck at the top of the head, that has a threaded port, specifically for the temperature probe. I did not have to cut (shorten) the upper hose.
Brian French; 1930 Briggs Town Sedan
Brianfrench65 is offline   Reply With Quote
Old 10-03-2016, 05:13 PM   #4
Walt Ebie
Walt Ebie's Avatar
Since I'm committed to the probe pipe in the hose, does anyone have some good hints on how to get the hose to slip on the rad and the block easier than plain old muscle power? Maybe talcum or some other trick that you used?
Old 10-03-2016, 05:17 PM   #5
racingrufus
racingrufus's Avatar
I also put the upper hose mount on the head for the temp probe. I could not use the pipe in the hose because I was useing a thermostat in upper hose. Dwayne
racingrufus is offline   Reply With Quote
Old 10-03-2016, 05:50 PM   #6
Jim/GA
Jim/GA's Avatar
Yes. Apply a thin film of Hylomar AF to the inside of the radiator hoses where they contact the radiator/block. They will slide on easy, they will not require a crazy tight hose clamp to keep them from weeping coolant, and they will come back off many years later with ease. (The rubber hose won't bond to the metal.)
I buy my Hylomar AF in a small tube from W.W. Grainger, but I am sure there are other dealers. It is amazing stuff.
Jim Cannon
Old 10-03-2016, 06:00 PM   #7
Big hammer
Also if you warm up rubber it will make more pliable. Soaking it in hot! water, something I didn't do last time I put hoses on :-(
Old 10-03-2016, 06:29 PM   #8
VFRhugh
VFRhugh's Avatar
I'm with #3. I installed the steel inline pipe with temperature connection. I works great but I pulled the hose to remove a thermostat and it's starting to rust from the inside after only three weeks. Using distilled water and Water Wetter.
Hugh
VFRhugh is offline   Reply With Quote
Old 10-03-2016, 06:56 PM   #9
CarlG
CarlG's Avatar
I use one of these - solves several problems:
Has a place for the temp probe as well as a receptacle for a thermostat (and a hot water heater hose).
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-03-2016, 07:50 PM   #10
goodcar
Ditto
goodcar is offline   Reply With Quote
Old 10-04-2016, 12:29 PM   #11
Bruce
Bruce's Avatar
If you use the probe tube, drill a hole in the (new) upper hose. Then cut the hose in half. Carve the hole so that when you insert the probe tube the little leg is sandwiched in the hole and the hose can be squeezed tightly together. Remember to put all four clamps on the hose, "dope" the cast Iron bits with ... Windex ... and stick it all together. If you've done a craftsmanly job, the red stripe will match up and the cut in the hose will be almost invisible.
A real CRAFTSMANLY job would be to use SST jam nuts/washers inside and outside a hole through the hose to sandwich the probe in the hose. I've seen vintage setups like that at swap meets. They were very pricy, but way-cool.
Bruce is offline   Reply With Quote
Old 10-05-2016, 08:55 AM   #12
captndan
captndan's Avatar
Grease?
captndan is offline   Reply With Quote
Old 10-05-2016, 05:18 PM   #13
d.
carl G, goodcar,
so where does one find this item? looks good.
d. is offline   Reply With Quote
