Old 09-20-2016, 02:09 PM   #1
RyanB
Default 1929 Speedometer Cable Routing
As I am working through the final wiring and instrument hookup of my 1929 coupe I can't figure out where the speedo cable routes and where the clip mounts to. I have an unrestored cabriolet of my grandfathers that I am using as a reference for a lot of things but the cable is being routed out of the electrical junction box and I don't think that is correct.
RyanB is offline   Reply With Quote
Old 09-20-2016, 02:16 PM   #2
29spcoupe
29spcoupe's Avatar
Default Re: 1929 Speedometer Cable Routing
The cable comes up the inside of the firewall. A small clip holds it in place against the fire wall, then feed it up through the 'tunnel' under the gas tank to the speedo.
29spcoupe is offline   Reply With Quote
Old 09-20-2016, 02:46 PM   #3
RyanB
If anyone has a picture where that comes in and where the clip goes that would be a huge help. There are too many dang holes in that firewall.
Old 09-20-2016, 02:47 PM   #4
Mitch//pa
Ryan
Here is a thread that will help you
http://fordbarn.com/forum/showthread...edometer+cable
Old 09-20-2016, 02:48 PM   #5
RyanB
You guys are the best. That is perfect Mitch. Thanks!
