11-22-2010, 11:15 AM | #1 |
Dumb Questions
#1, Is a 32 B transmission any better than my 31, if so will in bolt in?
#2, I have read about using a model T spring to lower the rear of a model A, does this work? A stock T spring? Thanks for any help. |
11-22-2010, 11:54 AM | #2 |
Re: Dumb Questions
Yes, yes, and yes. The B trans case has syncro 2nd & 3rd gears, and better ratios than the A trans. They will also accept any gears up to 1948 and in some cases later than that. Bolt in? Well, kinda but it takes a lot of effort. The easiest way is to buy an adapter kit from Cling's in AZ and use the V8 trans. e-mail me at [email protected] and I'll send you more info. The T spring is shorter and narrower but will fit right in and lower the rear of the A.
11-22-2010, 08:29 PM | #3 |
Re: Dumb Questions
