Old 04-10-2016, 12:14 PM   #1
mdenning
mdenning's Avatar
Question Oil Drips
I've got a 30 Fordor on the way. Never owned an A before. How do these things 'normally' drip fluids ? How many drip pans do I need under my parking space ?
mdenning is offline   Reply With Quote
Old 04-10-2016, 01:31 PM   #2
1Tudoor
1Tudoor's Avatar
Default Re: Oil Drips
An empty refrigerator box should map it out for you
1Tudoor is offline   Reply With Quote
Old 04-10-2016, 01:39 PM   #3
Nabco
Nabco's Avatar
I use four 18" x 26" cookie sheets under my coupe, they work perfectly and my wife didn't notice them missing for a couple months!!!
1930 Deluxe Coupe
"Sister"
Nabco is offline   Reply With Quote
Old 04-10-2016, 02:10 PM   #4
3thumbs
I replaced the engine in mine with a new one from Bert's. That leak is taken care of, but the Mitchell tranny, Overdrive and the rear end all leak. I put cardboard from the tranny all the way to the back bumper.
3thumbs is offline   Reply With Quote
Old 04-10-2016, 02:23 PM   #5
rocket1
I would buy Exxon stock.
rocket1 is offline   Reply With Quote
Old 04-10-2016, 02:36 PM   #6
C26Pinelake
The old story is they don't leak, they mark their territory, like a dog ! Wayne
C26Pinelake is offline   Reply With Quote
Old 04-10-2016, 03:06 PM   #7
Bob C
Something like this should work.
Bob
Bob C is online now   Reply With Quote
Old 04-10-2016, 03:48 PM   #8
5lugnuts
I have used old carpet cut to 30 in wide. When working on something messy under the car in the driveway I use a moving blanket from Harbor Freight. It soaks it up and I can lay on it.
I'm not saying drain the oil on it, just catch drips and slops.
5lugnuts is offline   Reply With Quote
Old 04-10-2016, 03:57 PM   #9
Tony S,Fl.
Tony S,Fl.'s Avatar
I live in Pompano Beach. We have an active club. We can help you. We would like you to be a part of our club. We meet every 2nd Saturday of the month at Lesters Diner on Coconut Creek Parkway at 9:00 A>M> Come on down and have breakfast and enjoy the meeting. In fact we will have our Tune up and Tube steaks this coming Saturday at Quiet Waters Park on Powerline Rd. I'm sure you will like it. If you have your Model A or come modern . Tony
Tony S,Fl. is offline   Reply With Quote
Old 04-10-2016, 04:40 PM   #10
Brianfrench65
Brianfrench65's Avatar
I was told, if it does not leak oil, there's likely no oil in it.
Brian French; 1930 Briggs Town Sedan
Brianfrench65 is offline   Reply With Quote
Old 04-10-2016, 05:23 PM   #11
katy
katy's Avatar
I use one 47" L x 25" W under the engine and transmission and a piece of cardboard under the rear axle/differential that doesn't leak.
I have 4 of them 47" L x 25" W pans (available from NAPA) that I use for different vehicles.
Old 04-10-2016, 05:35 PM   #12
jrelliott
jrelliott's Avatar
Model A's do not drip oil, they simply mark their territory. I use a couple of pieces of cardboard about 24" by 48" under the engine and tranny and a oil changing pan under the differential. Most of the Model A's when they were produced if kept inside were in garages that had dirt or gravel floors so why worry about drips. With modern garage floors that are concrete or painted concrete every drip shows.
Old 04-10-2016, 05:48 PM   #13
30ccpickup
30ccpickup's Avatar
I use old bed pans, for some reason it seems appropriate.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 04-10-2016, 05:55 PM   #14
stouchton
stouchton's Avatar
I use a plastic wrapping paper storage thingy lined with newspaper. Extends from the engine oil drain back to the universal.
My differential does not leak... I guess I need to check the level ?!?!?!?!?!?
stouchton is offline   Reply With Quote
Old 04-10-2016, 06:42 PM   #15
Mitch//pa
No pans needed under my cars and all the fluids ARE full.. If you need a pan then one or more things needs attention, it's not normal to have leaks
Old 04-10-2016, 08:09 PM   #16
mshmodela
mshmodela's Avatar
Some cars leak more than others. Those with newer restorations will naturally leak less or none at all. I would guess my car was restored about 15 years ago... It leaks very little but if I had my engine rebuilt I would expect no oil drips.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 04-10-2016, 08:43 PM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Vermin hasn't leaked a DROP, in 2 years! "Someday" I'll finish & fire him off!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-11-2016, 12:19 AM   #18
ian Simpson
All three of our collectors sit over rubber backed bathmats. Only the 57 Chev needs a diaper.
ian Simpson is offline   Reply With Quote
Old 04-11-2016, 12:41 AM   #19
Mike V. Florida
Mike V. Florida's Avatar
http://www.goldcoastmodela.com/
Old 04-11-2016, 09:14 AM   #20
BILL WILLIAMSON
Old braided oval rugs work SUPER & last a long time. They're VERY ABSORBENT & look very DECORATIVE!
Bill W.
