Friend sent me this B carb to check over ( it is fitted to a stock A engine with gravity feed tank) - All the symptoms he describes (stalling/stuttering when trying to power up hill etc )point to fuel starvation. Fuel level is 5/8 inch below gasket
No surge baffle with the float (has it been removed or are some like that?}Is the baffle essential? Fow rates test out ( ml/min at 36 inch): main 88, cap 390, comp 158, power 35. Biggars book recommends, main 136-142, cap 372-462, comp 110-118, power 110-118. I don't want to take all the airway plugs out- the carb looks very clean. Apart from some of the jets being obviously way out are any other things I should be aware of? IMG_1200.jpg Last edited by johnbuckley; 07-05-2016 at 11:35 AM. |
Your starving fuel because of a plugged main jet. Get them all to specs first. Check your throttle shaft for wear.
Also check the ignition, many carb are actually ignition problems.
has he opened the GAV more.....it is there to play with....many fuel starvation issues are because the GAV is turned in too far....don't be afraid of it
'31 180A |
Chuck Sea, the throttle shaft certainly has some play. I find the A carb is fairly forgiving with throttle shaft wear... But is it more critical on the B carb? Would this play cause lack of suction up the power jet, with the controlled port leaking?
Nothing can be made foolproof, ---- fools are ingenious bastards. Last edited by Brian T; 07-05-2016 at 12:55 PM. Reason: Added Text |
Make sure the small hole in the throat or passage way , where the fuel from the pickup tube exits when the throttle is opened, is not plugged.
Ron |
I don't know anything about a B carb, but if the fuel line goes in too far, like it can on an A carb, and hits the screen in the carb, this is exactly what happens. A little circumcision of the tube will fix it.
The 32 B and 33-34 C passage ways and throat is no way like the Zenith- or Holley Carburetors that came on the A.
Ron |
check to see what color the spark is and how far it jumps.
