Old 06-28-2016, 04:07 PM   #1
J Witt
J Witt's Avatar
Default '36 front axle bumpers
While getting the engine ready to come out, I noticed the front axle bumpers are hard as rocks and cracked, so have a new pair on the way.
Question is, the bumpers look like they just ride up and down on the bolts through the frame holes, without anything positive to keep them on. The ones I removed only had a flat, split lock and nut on the stud and weren't tight enough to have the lock washer do anything.
Advice anyone? Guess I can always put a drop of thread lock on them.
Thanks,
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 06-28-2016, 04:28 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: '36 front axle bumpers
iirc, they have a notched mounting to the frame, which keeps them from rotating when the nut is being tightened.
Karl Wescott is offline   Reply With Quote
Old 06-28-2016, 05:48 PM   #3
19Fordy
19Fordy's Avatar
They screw tightly against the frame. You can also see the notch.
https://www.bobdrake.com/FordItem.as...e-bb93c698fef0
Old 06-28-2016, 06:01 PM   #4
Don Rogers
Don Rogers's Avatar
Here's a picture of the front axle bumper showing notch and mounting hardware. ( From 1935-36 Ford Book)
Don Rogers is offline   Reply With Quote
Old 06-28-2016, 07:04 PM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
These axle bumpers are made of a hard (high durometer) rubber material for a good reason. They normally take a beating on rough roads, especially back in the day when these cars were new. I know mine got a good workout on the Interstates I traveled (70 and 44) during my recent road trip.
John
Old 06-28-2016, 07:51 PM   #6
DavidG
DavidG's Avatar
Note in Don's illustration that no flat washer was used, unlike what you encountered on disassembly of the existing bumper. Such a washer serves no purpose when the stud passes through material the thickness of a frame rail and can actually lead to a loosening of the nut.
Old 06-28-2016, 07:58 PM   #7
J Witt
J Witt's Avatar
Is the notch supposed to line up with something or is it just there to vent the interior space? Both of mine were full of rusty water when removed, probably from recent pressure washing.
I take it from these posts that the nuts should be tight, at least tight enough to set the lock washers.
Thanks for the information, guys.
Old 06-28-2016, 09:49 PM   #8
Don Rogers
Don Rogers's Avatar
The notch allows the bumper to fit over the head of a large frame rivet. I believe that the rivet is one of many attaching the front cross member to the side rail.
Old 06-29-2016, 01:55 PM   #9
J Witt
J Witt's Avatar
That worked out exactly as you said, Don. The notch keys on to a rivet head with a perfect fit -- notch is on the forward side of the bumper.
I did do a small modification, drilling a 3/16 hole on an angle from inside to out to allow that cavity to drain. Don't know if it matters, but the frame was rusty in the area where the base of the bumper contacts the frame.
