Old 06-22-2016, 06:12 AM   #1
guy1unico
Default 6 volt fuel sending unit
Who makes one that works in a 1933 Ford gas tank or a universal 6 volt unit?
Thank you
Guy
guy1unico is offline   Reply With Quote
Old 06-22-2016, 06:53 AM   #2
JSeery
JSeery's Avatar
Default Re: 6 volt fuel sending unit
The sender needs to match the gauge you are using. If it is an original gauge it needs an original sender to work best (however some users claim to get a resistance sender to work). A modern gauge needs a sender that matches the resistance range of the gauge.
Interesting article on installing a modern sender (and gauge) in a 32 tank. http://www.hotrodhotline.com/install...r#.V2p8lY-cGUk
