1. How do you keep an aluminum manifold from darkening up again after sandblasting?
2. How do you keep sandblasted exhaust manifolds from rusting? 3. Has anyone used stainless steel head nuts? |
Some ideas for:
#1. Clear powder coat #2. Clear ceramic coating #3. Stainless steel head bolts can't be used. Not strong enough and they gall. IMO. But...........ARP makes them. Last edited by 19Fordy; 06-12-2016 at 08:49 AM. |
There is another question you should ask too---how do you clean all the sandblast media out of the internal manifold passages so it doesn't get sucked into the engine
for the exhaust manifolds there is paint that is applied and baked in a oven, it can be in different colors |
#4 | |
![]() Quote:
2. I tried the paint/bake thing a few times but couldn't make it stay very long. l Had them Jet Hot ceramic coated 4 years ago. They still look new. 3. Stainless Steel nuts and bolts are too soft and maleable. They stretch too easily to hold under that much heat. |
#5 | |
![]() Quote:
I have never had an issue cleaning them thoroughly after stripping. As you know quite well, patience, patience, patience... I powder coat my exhaust manifolds after sand (yes, sand) blasting. Holds up seemingly forever. I have not used stainless head nuts as I prefer to restore my cars to original appearance. I do not believe galling would be an issue as a previous post has allowed if the stud (threads) were clean.
In aviation we generally only use stainless hardware in very high heat situations. The fasteners that work the best are silver plated but they are a one use item in extremely high temp applications and should be replaced after removal. Most plain stainless fasteners used in very high temp applications have to be destroyed to remove them. I got really good at drilling the bolts out of the aft end of the T-53 Huey engines when doing hot section inspections. We used a lot of bees wax and cobalt drills. I also got good a sharpening the dull bits. PITA for sure. |
