Old 06-10-2016, 02:38 PM   #1
Dumptruck
Default Is this wheel bad
Is this the rh-5° widowmaker?
Dumptruck is offline   Reply With Quote
Old 06-10-2016, 03:19 PM   #2
truckdog62563
truckdog62563's Avatar
Default Re: Is this wheel bad
Yes. The raised band like area seen on the concave rim side is the joint. I see you tried to private message me again, but there was no content. Was it a hiccup, and this solves it? Below is a cross section of the RH-5°. Stu
Stu McMillan
Marmon-Herringtons
truckdog62563 is offline   Reply With Quote
Old 06-10-2016, 03:31 PM   #3
41panelmark
41panelmark's Avatar
Let's see the rest of the truck, keep an eye out for some of the other versions of splits, better and more safe.
41panelmark is offline   Reply With Quote
Old 06-10-2016, 03:42 PM   #4
truckdog62563
In my private message yesterday I recommended he find the 19.5" tubeless wheels. I avoided going into the explanation of other options because the 19.5" tubeless are his best solution matching closely his 7.00-18s. Finding 20" locking side ring tube type wheels would be fine, but sometimes I can see new guys eyes glazing over when we get into the subject. If it's something to hear about, please say. Stu
Stu McMillan
Marmon-Herringtons
Old 06-10-2016, 03:50 PM   #5
Dumptruck
I tried to send the pic of the wheel but couldnt get it to post, that is why i started the thread
Old 06-10-2016, 03:55 PM   #6
Dumptruck
I havent cleaned it up yet and the racks are in the barn and look like new, i know the history of the truck since new, but ive got alot of work ahead of me but the truck runs good dump bed works as new
Old 06-10-2016, 04:15 PM   #7
truckdog62563
Truck looks to be in great shape. Here's another member's F-4 that has a set of the Budd 89340s I described. Stu
Stu McMillan
Marmon-Herringtons
Old 06-10-2016, 06:23 PM   #8
49fordv8f4
49fordv8f4's Avatar
Great looking F4! I'm working on a '49 F4 also. The 19.5" wheels are a good choice for these trucks, I have a set that I will be using on mine. They also drive better with radial tires. I have a hoist under my Ford script bed as well. It was installed under the bed when the truck was about a year old. I did have to do a lot of repair work on the bed frame, as they welded it to the hoist frame and it had a lot of breaks in the bed crossmembers. I also have the racks for mine but the wood will need to be replaced.
Mark
49fordv8f4 is offline   Reply With Quote
Old 06-10-2016, 08:48 PM   #9
Dumptruck
I have a lot of memories hauling corn, hay rides and just running around in that old truck. It was used steady as a farm truck till about 6 or 7 years ago. I think the actual mileage is about 59000
