Old 11-05-2010, 03:28 PM   #1
Russ/40
Russ/40's Avatar
Default Gas leak at column support
Before I did the body and finish work on my '29 gas tank, I put a few gallons of solvent in it to check for leaks. I found none. Now that it is ready for final paint, I see a slight weep at a corner of the column support bracket. Is there a successful way to stop this weep without destroying all my body work?
Old 11-05-2010, 04:07 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Gas leak at column support
No, not unless you want to move the support to the dash rail.
Old 11-05-2010, 07:16 PM   #3
Russ/40
Russ/40's Avatar
Actually I have a rail mount I was considering using. What do you do with the existing support? Does it get in the way? If I use it, how do I stop the existing seep?
Old 11-05-2010, 07:47 PM   #4
b ramsey
i had the same problem, used some sealer called red-kote. it works so good, you cant buy it in california. i bought 2 quarts and only used 3/4 of one.
b ramsey is offline   Reply With Quote
Old 11-05-2010, 07:51 PM   #5
IrishHills
IrishHills's Avatar
I used a 2 part apoxy gas tank repair kit from local parts place, worked great on an oil pan that I had leaking, turned rock hard and lasted for years, got to clean the metal good though.
IrishHills is offline   Reply With Quote
Old 11-05-2010, 08:04 PM   #6
Steve Ciccalone
Steve Ciccalone's Avatar
WARNING ABOUT TANK SEALERS! We just had a case of Redcote failing in a newly restored '27 Indian Chief tank destroying the paint job. My POR15 coating that I always swore by is breaking down due to the Ethanol in my Hendersons. I've recently seen that the percentage may be increased to 15% from 10% in gas. More problems coming. As your tank is not painted yet, I would take it out, excavate the crack and repair it by welding, brazing.
"A wet bird doesn't fly at night."
Steve Ciccalone is offline   Reply With Quote
Old 11-05-2010, 08:08 PM   #7
dmaxweb
dmaxweb's Avatar
In my case the bracket was very solid to the tank but there was a very very small seep in one spot at the top of bracket.
After cleaning and sanding on and around the tank bracket, I brushed on a good coat of Marine Tex Gray epoxy.
The dash rail bracket dropped the column about 1/4" leaving clearance to the old bracket. Haven't seen or smelled a seep of gas since.
Marine Tex is one tough epoxy. You can get it on ebay for about $12 for a 2 oz kit. You will only need a small amount of it.
Good Luck
dmaxweb is offline   Reply With Quote
Old 11-05-2010, 08:14 PM   #8
ford1
Steve is right, the only way to permanatly fix a gas tank leak is to silver solder or braze it, and if it has a straight line crack i would drill a very small hole (1/64 drill bit) at each end of the crack to stop it from traveling any farther, take a pecking hammer and put a small indention over and beyond the crack to give the repair material more area to bond to so it wont crack there again
ford1 is offline   Reply With Quote
Old 11-05-2010, 09:52 PM   #9
Model T Monte
Steve, I hate to hear of your bad experience, BUT-- I really hate the fact that I just used redcoat on a 26Rdstr less than a year ago and less than 30 miles of drivein on it. Monte
Model T Monte is offline   Reply With Quote
Old 11-05-2010, 10:14 PM   #10
Russ/40
Russ/40's Avatar
The bracket seems very firm on the tank, and leaks from about a 1/8" spot.
Old 11-05-2010, 11:09 PM   #11
FL&WVMIKE
FL&WVMIKE's Avatar
Steve Ciccalone ........................
Did you see my thread, that had a list of stations, by state, that sold Ethonal-Free gasoline ?
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 11-06-2010, 07:18 AM   #12
Steve Ciccalone
Yes I did Mike. Unfortunately only one station in New Hampshire in a town called Freedom! It is in fact the only station in new England that is listed. I have to rent a tanker.
Old 11-06-2010, 07:52 AM   #13
Mike V. Florida
Use it! Remove the bottom part of the old clamp and it will not interfere at all.
Once this is done you can use any of the suggestions given for the leak.
I'm afraid that if you don't move the clamp, no matter how you fix the leak it will return.
Old 11-06-2010, 09:46 AM   #14
Paul from Maine
Paul from Maine's Avatar
Take it to your local radiator shop and have them solder it up. That is whatI did this spring and have had no problems since. I bought a dash support, but have been too lazy to install it. I'll regret it when I have to take the tank back to the radiator shop!
Paul from Maine is offline   Reply With Quote
Old 11-06-2010, 11:01 AM   #15
dean from bozeman
dean from bozeman's Avatar
Has anyone developed an air pressure method to check gas tanks for leaks? Seems like a bit of air pressure with a water soap mixture would help detect any leaks.
dean from bozeman is offline   Reply With Quote
Old 11-06-2010, 12:51 PM   #16
31rpu
Order PRC fuel tank seal from one on the aviation supply houses. Vans Aircraft, Aircraft Spruce are two that come to mind. This sealant is used to seal fuel tanks on aircraft. Clean the area around the mount, apply a thin coat and paint will stick to it.
31rpu is offline   Reply With Quote
Old 11-06-2010, 01:56 PM   #17
TK in LA
TK in LA's Avatar
I made a gas tank pressure tester by using an old radiator cap. Drill out the center to accommodate a valve stem from a mag style wheel. They have a rubber gasket to keep them from leaking. Just be careful how much pressure you use. A little goes a long way. To much pressure and you may create more holes that weren't there before. Just my 2¢
TK in LA is offline   Reply With Quote
