Old 05-26-2016, 05:58 PM   #1
russcc
Default Pop back through carb.
The original engine in the '40 is plenty tired, but starts right up, and runs pretty well. Have not been out on the road yet. with it. When sitting still, and you crack the throttle pretty good, it will pop back through the carb frequently. Is that an indication of a lean fuel condition ? Thank you Fordbrainers.
Old 05-26-2016, 08:14 PM   #2
Init1
Init1's Avatar
Default Re: Pop back through carb.
Yes it could be lean but could also be a bit retarded.
Try checking the timing first before you go to the trouble pulling the carb.
Init1 is offline   Reply With Quote
Old 05-26-2016, 09:38 PM   #3
39topless
Poor some Marvel Mystery Oil down the carb with the engine running at idle. Continue until it starts smoking good and almost stalls. That should help loosen up those sticky valves. Always add about 1/4 pint of the MMO to every gas fill up.
39topless is offline   Reply With Quote
Old 05-26-2016, 10:04 PM   #4
A bones
A bones's Avatar
Intake valve not sealing. Use Marvel Mystery Oil as 39topless said. Give it time, I had one go near a month of daily use 'til better.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 05-27-2016, 06:24 AM   #5
russcc
Thank you all for tip off. MMO it is.
Old 05-27-2016, 09:12 AM   #6
Bored&Stroked
Bored&Stroked's Avatar
Could be a stuck valve . . . but also check and see if the accelerator pump is squirting in the carb. Sometimes when you stab the throttle, with no pump squirting, the engine will go to a heavy lean state (temporarily), then when the rpm picks back up, it will run just fine. When I've had stuck valves, they tend to be stuck all the time and I have pop-back and other issues at any higher RPM - it doesn't usually go away.
You might also run a compression check on all cylinders - see if you have one or more that are leaking/low.
Old 05-27-2016, 01:20 PM   #7
jhb
jhb's Avatar
I had that happen once on a 351 Windsor and it turned out to be a bad spark plug wire, how are yours ? Let us know when you find out....................jhb
jhb is offline   Reply With Quote
Old 05-27-2016, 02:01 PM   #8
deuce_roadster
deuce_roadster's Avatar
I had a cheap condenser go bad and it caused the coil to fire at the wrong time, the backfire through the carbs set the oil on the K&N air filters on my 97s on fire, burnt the paint off the hood of my avatar roadster 10 years ago. I would change the condenser and see if the problem goes away. No longer use K&N for anything.
Old 05-27-2016, 02:43 PM   #9
WestCoast
usually a sticking intake valve, marvel mystery oil will usually fix that, drive a 100 miles of so
WestCoast is offline   Reply With Quote
