Old 05-13-2016, 01:33 PM   #1
Dick Steinkamp
Dick Steinkamp's Avatar
Default "Acceptable" bearing clearances
I pulled the pan and started checking bearing clearances today.
The rods don't have any shims left, but the bearing material (at least on the cap) still looks good. I Plastigauged #1 and there is about .0025 clearance.
The Mains still have some shims left. I plastigauged the middle one and got >.003 clearance. Removing a .003 shims from each side gets me to about .003 clearance with one .002 shim left on each side. So it appears I can get the mains back into spec if the other two are similar.
My question is, how bad is .0025 clearance on the rods? Will they knock? Hurt the crank? Be OK for a while?
Dick Steinkamp is offline   Reply With Quote
Old 05-13-2016, 01:51 PM   #2
DJ S
DJ S's Avatar
Default Re: "Acceptable" bearing clearances
.0025 is an acceptable clearance. I start to worry when clearances exceed .003.
DJ S is offline   Reply With Quote
Old 05-13-2016, 02:07 PM   #3
Patrick L.
Patrick L.'s Avatar
I think .0025" is about the limit. I've seen [ well, actually heard] them rattle at .003" .
Old 05-13-2016, 02:39 PM   #4
Art Newland
Art Newland's Avatar
I'll be able to hear you coming!
Art Newland is offline   Reply With Quote
Old 05-13-2016, 04:14 PM   #5
Dick Steinkamp
That's the up side!
Old 05-13-2016, 04:24 PM   #6
Dick Steinkamp
Thanks, guys. I'm going to plastigauge the rest of the rods. If they are .0025 or less, I'll move to the mains and hopefully be able to use this engine a little more.
Old 05-13-2016, 09:03 PM   #7
Jim Brierley
Your rods are nearing their limit. You can carefully file, or better yet take the caps down a little on a surface plate using sandpaper. Apply more pressure to the side with the most clearance, if there is one.
Old 05-13-2016, 10:52 PM   #8
tbirdtbird
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-14-2016, 06:58 AM   #9
Mike V. Florida
Mike V. Florida's Avatar
Tony S. tells the story that when he was younger and money was non existent, he would take his A drive it up in the curb, drop the pan and remove the bearing caps and rub them on the sidewalk to get the clearance they needed to quite the engine.
Old 05-14-2016, 09:40 AM   #10
Dick Steinkamp
Originally Posted by tbirdtbird View Post
You removed shims from the center main.
Be reminded that you cannot remove more from the center main than you remove from the rear main.
So, let's hope that you need to remove the same amount of shims from the rear main.
We just had a guy on here last week who took more from the center than the rear and ended up needing 40 pounds on a torque wrench to move the crank, when it should move freely. He put the shims back in.
What prompted you to 'pull the pan and check clearances?'
Don't you also have a Stude?
Thanks. I do intend to roll the motor over with the crank (plugs out) after every rod and main adjustment to make sure I haven't done something stupid (Unfortunately, I do have a history for that )
I have not run this car very much. The other day, however, I let it idle for 45 minutes or so and the motor sounded noisier than I thought it should be when it was fully warm. No knocks and no change when the throttle was tipped in but I thought I'd better take a look at the bearings for peace of mind. I wanted to clean the pan out anyhow. I'm glad I did. It looks like I can get away with the rod clearances, but the mains need to be tightened up some.
I've built and owned many Studebakers. The two that were best known were my 54 Starliner hot rod...
...and my 53 Starlight Kustom (the Kart Hauler)...
No Studes in the fleet now, however. Besides the A, I currently have an MGB that I've put a Rover aluminum V8 and Camaro T5 in...
[/url]
...and a 69 Mercedes W114 250...
ALL cars are fun and I'm thoroughly enjoying learning about Model As again after a 50 year absence from them, wrenching on it, and hopefully playing with it after I get it safe and dependable.
All steel from pedal to wheel
Old 05-14-2016, 11:07 PM   #11
Flathead
Flathead's Avatar
Some nice cars you got there.
Flathead is offline   Reply With Quote
