Old 05-13-2016, 08:06 PM   #1
12secvx
Default My attempt at restoring a powerhouse generator
I got a used powerhouse generator on a engine I paid $50 for last year and I had a new set of brushes I got wit a lot of NOS ford parts. So I decided to see if I could bring this old girl back to life.
12secvx is offline   Reply With Quote
Old 05-13-2016, 08:12 PM   #2
12secvx
Default Re: My attempt at restoring a powerhouse generator
I found that the field wire had shorted out against the back cover. Also that the field coils were good but the wrap had got brittle and came off a bunch over the years. So I removed them and used cloth tape and liquid electrical tape to do my best at rewrapping them.
Old 05-13-2016, 08:15 PM   #3
12secvx
More
Old 05-13-2016, 08:18 PM   #4
12secvx
And the finish product after cleaning it all up. I have a bunch more pictures but t will only allow one per a post for some reason.
Old 05-13-2016, 08:37 PM   #5
Rowdy
These generators are very rugged. I pulled one out of the dirt. Hard to tell how many decades it had been there. Took it home gave it a general cleaning, slowly got it to turn and then gor the brushes to move again and had it working in less than an hour. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-13-2016, 08:53 PM   #6
12secvx
I would have to agree Rod all mine really needed is a good cleaning but I did do a light file clean up of thecommuntator and new brushes anyways. Also installed a diode I had laying a box of old parts in the original cut out also. The stamped steel pulley was a little wobbly and bent so I have since added a cast pulley instead. I have only done a bench test on it by motoring it with a 6v battery.
Old 05-13-2016, 09:29 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Looks nice. Don't throw away worn brushes, because new carbon brushes can be cut to size, but the wires and terminals are the hard parts to find.
Sure wish Ford had used the powerhouse for all the Model A's.
Old 05-14-2016, 12:07 AM   #8
Floats
Floats's Avatar
Hi Gents,
Any ideas or pointers where to find Powerhouse gennie parts will be much appreciated. I need bushes and brushes.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 05-14-2016, 01:21 AM   #9
diomed
diomed's Avatar
Tom, could you make new connector wires with these?
http://www.britishwiring.com/3-16-Fl...let-p/c272.htm
kris
diomed is offline   Reply With Quote
Old 05-14-2016, 02:52 AM   #10
Tom Wesenberg
Is 3/16" the hole size, or is it the width of the terminal?
At $.70 each, that would add $3.50 to the cost of making a 5 brush set, and you still need to buy the flexible wire and carbon brushes.
Old 05-14-2016, 03:43 AM   #11
diomed
diomed's Avatar
3/16" is the hole size.
Sent from my Nexus 9 using Tapatalk
kris
Old 05-14-2016, 08:05 AM   #12
12secvx
Luckily the original bracket and stud was still attached after all these years.
Old 05-14-2016, 09:27 AM   #13
Tom Wesenberg
That would be a bit large for the number 6 screws used for the powerhouse brush terminals.
Old 05-14-2016, 10:28 AM   #14
diomed
diomed's Avatar
Wow, yeah that is quite a difference on a #6.
Sent from my Nexus 6P using Tapatalk
kris
Old 05-14-2016, 09:56 PM   #15
al's28/33
al's28/33's Avatar
Have Tom W. install his EVR unit and it will save your generator life and give you more reliability!!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
