I was thinking of putting one of these in my '36.It looks as though the starter is a 21 stud. Should I add more leafs to the springs?
https://www.youtube.com/watch?v=Y0DbYlqXgUs |
Maybe some bigger brakes would be needed along with heavier springs. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
I thought his jacket sleeve was going to get wrapped up in the generator pulley and belt for sure.
The Ford GAA was a lot like an aircraft engine the way it was designed. It worked very well in the Sherman easy 8 tank but was a bit under powered in the M-26 Pershing tanks. The later versions M-47/48 types changed over to larger engines and the later ones were mostly diesels.
#5 | |
![]() Quote:
Alan |
#6 | |
i had a GAA once that i saved out of a junk yard in kansas. they were used for well pump motors after the war. for something really wild, look up the chrysler multibank tank motor, 5 flathead sixes mounted on a common crankcase, star shaped. they worked well, but few were made
It originally was a v12 for aircraft. But literally didn't get off the ground for that purpose. So off with four jugs and a tank engine was born. Or so I've read. Oops, quoted the wrong person.
I dig coal, which provides motivation for EVs. |
Every year Sarafan's in Spring Valley, NY would have an open house in the 70's and 80's and our club here in Conn. would go down and see what goodies he had. There was a Sherman out front and it had that engine. We'd get it running and drive it around the property (small) . It was fun to tinker on it and see if we could get it to start! After that, it would sit all year until the next open house. Back in my Olive Drab days!
Barry 50 F-1 |
Not a flathead if it's DOHC.
