Old 04-05-2016, 01:17 AM   #1
sunnyorm
sunnyorm's Avatar
Default Gas starved? compression? vacuum leak?
6 months ago I took an around the block test.
Started 2nd or 3rd crank.
Seemed to idle ok.
Took off down the street, and first acceleration got a couple loud backfires, then then ok.
Drove 1 block, saw school bus unloading, so shut engine off, 4 minutes later, started up first crank, no backfire.
Drove the 1 block back to house, engine very hot, spitting water everywhere, carburetor spitting some gas out.
After this could not get started, no matter what my mentor and I tried.
Only thing that started it once, and only once, was by pulling and holding choke out when cranking 5 or 6 times.
Hasn't started again since.
cylinders are all below 35-40, installed new head gasket.
Anybody with suggestions? (silly question)
Thanks
sunnyorm is offline   Reply With Quote
Old 04-05-2016, 06:44 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Gas starved? compression? vacuum leak?
Stripped timing gear?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-05-2016, 09:36 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Back to basics. Start by checking for a hot blue spark that will jump 1/4", then check the timing, and gas flow at the carb. Your engine should run with low compression, but that could be sticking or burned valves, or excess carbon, or a bad head gasket.
In the meantime take a break and watch this short video on having final fun with your junk cars and pickups.
https://guyviral.com/auto/country-bo...emolition/?v=2
Old 04-05-2016, 09:54 AM   #4
Mitch//pa
Tom pretty much covered it ...
we have no prior history mentioned to go on...
Old 04-05-2016, 10:33 PM   #5
sunnyorm
sunnyorm's Avatar
Ok Thanks, will investigate further.
oh by the way Tom, I decided to watch the video first, now my A is just a big pile of nothing.
must of misread something??
Old 04-06-2016, 04:20 PM   #6
colin1928
colin1928's Avatar
Check your timing had a friend whose timing was way retarded acted the same run bad and hot
colin1928 is offline   Reply With Quote
Old 04-06-2016, 05:26 PM   #7
H. L. Chauvin
Reply no. 2 possible failure suggestion is very logical with your no start details thus far mentioned ..... quick check for stripped teeth on a timing gear would be to rotate engine and verify that your distributor is rotating.
Just keep giving details and keep asking ...... this Forum is loaded with compassionate gentlemen trying to assist others.
H. L. Chauvin is offline   Reply With Quote
Old 04-15-2016, 11:46 PM   #8
sunnyorm
sunnyorm's Avatar
Checked timing gear, with several revolutions of the hand crank, distributor turning fine. other priorities keeping me away from trying more suggestions, will keep at it.
Old 04-16-2016, 08:09 AM   #9
chap52
chap52's Avatar
Remember, "This is a Hobby"... Keep posting, you will figure it out.
