Old 08-07-2015, 11:24 AM   #1
burner31
burner31's Avatar
Default Turn signal switch debate - which one
I'm pulling the trigger on installing turn signals, going to use a 3rd brake light/turn signal in the back window along with the two mounted in the rear bumpers and converting the cowl lights for use as turn/driving lights.
My big decision is what type of switch to use:
The big unit with 4-way flashers
The small more classical look
or
The hidden type
What do you use, can you post some pics so I can get an idea of what each would look like installed.
Getting way too many close calls not to do this...not to do something
Keith
Shawnee OK
'31 SW 160-B
